Brett is right in what he said about the root cause however I wouldn't blame the vcam you just need to tune around it.
I ended up bowing the cylinder walls between each cylinder, causing the fire rings not to seat properly. This was caused by the high cylinder pressures I was generating with such a responsive setup.
What we have done now (other than going to an rd28 block and a slightly larger turbo) is to torque manage the curve and slowly bring the boost in rather than bring it in in one giant slab.
Whilst it doesn't give you that huge push in the low to mid range it used to it is fairly linear whilst still retaining plenty of mid range.
It has been rock solid now we have done that and I am confident the same could be done with a 6870, 3.2, vcam as well. The only problem with that is it was mostly over by 7 so you aren't seeing the benefits of making it linear and revving the car out to 9k+
Variable valve timing should be tuned to optimise VE.
The better the VE the more power you can make with less boost. Less boost means less EMAP. Pumping losses are lower.
 if you improve VE and still run more boost and the engine breaks thats on you. The Dyno told you how much torque you were making.
If you try to hit a power target with poor VE, you need more boost. You have more EMAP and higher pumping losses to overcome. The engine is more stressed at the same power output as the losses are higher.
You should be tuning an engine to torque. A turbo engine will make peak torque as it crosses peak efficiency of the compressor. This is towards the midrange airflow/revs of most engines.
  • Like 3
4 hours ago, Dose Pipe Sutututu said:
I would dare say motor with more boost thrown at it with the intake cam not advanced, i.e. VCT off at 6500rpm will survive vs. motor with less boost and VCT on at 6500rpm making the same 500nm at 6500rpm.
DYOR, this is not tuning advice.
Don't get confused here, I wasn't asking for advice - I've been tuning built and stock bottom end turbo cars for over a decade with NVCS or some kind of constantly variable cam timing and have not yet broken one despite being purely adjusting cam timing to suit the real world performance of the car.   I've not heard of anyone sizing or adjusting static cams in regards to bottom end longevity, either.
I'll pay attention next time, but I'm pretty sure there has been a very very close correlation between the torque developed and fuel consumption at any given rpm when changing cam angles...  which suggest there is no major variance in mechanical efficiency when adjusting the cam timing at WOT, which is realistically the only thing which could result in more cylinder pressure being required to achieve the same torque level.... so realistically there will be pretty much the same amount of air and fuel in the cylinder at the time the fire is started whether you use cam timing or boost to try and achieve the torque level, the valves will all be closed at the time so the burn should progress in pretty much the same way, so it really gets a bit hard to explain how there could be any difference in the force the bottom end goes through.
To me it seems to go back to being sensible about how much torque is delivered when, which you have a combination of cam timing, ignition timing and boost control available to help you manage.... whichever way suits your tastes or situation better.
That sucks to hear, gutted you had so many issues - otherwise sounds like a potent setup.   The bottom part makes complete sense.   The trick with comparing how it went with the 6870 with and without the boost coming in as hard as it could is it is possibly a false economy type of comparison as how much torque it made down low was not really maintainable, if you'd never had that then it wouldn't necessarily feel like it was lacking.   If the boost curve was brought in a bit more progressively then the shape of the curve would also make it look less like its fallen off a cliff at 7000, and arguably look/feel like a more conventional kind of power curve... albiet MEATY.   It would still have been a complete animal of a road car, would still be very responsive down low etc.... just not quite as psychotic as I'm sure it ended up being.
I think the discussion was at the time that you wanted >600kw without giving anything away down low to the 2.6/EFR8374 - I'm sure it would have been able to do that without going full send from the start of the rev range, albeit while possibly not having the EFR-esque transient response.
  • Like 1
What I have now is very much like the old 2.6 efr setup albeit with 800kw instead so I am quite happy.
Was just a learning curve for everyone involved and a bit of trial and error.
Very happy with the car now, absolute weapon and still plenty of mid range :)
That's insane, nice work :)  Its on a 7275 now?
The old 2.6 EFR setup is still kinda the benchmark for RB26s for me, never experienced one anything like it.
Yes 7275 now. Funnily enough when it was tuned in the same manner the 6870 was the response was quite similar which suggested the 6870 was a bit small all along.
Wow, that's pretty eye opening.  Definitely when a conversation about it came up at the time it felt like I was saying something crazy suggesting that a 6870 would be fine streetability wise on a 3.2+VCam - wouldn't have considered the 7275 would be a viable parallel to an EFR8374 on a 2.6, and feel like if someone had showed up and claimed that at the time they'd have been looked at like they were an alien.  Times have changed a bit :D
Well done on an epic build anyway, been good seeing it in the Coota videos - absolute beast.  Hard not to build something at that level without going through a few challenges and learning stuff along the way.
Edited by Lithium
  • Like 1
So what you’re both saying is the 6870 on a 2.8 doesn’t sound like the dumbest thing in the world and seeing some results could be interesting?
  • Like 1
I've never said it was the dumbest idea, I just made it pretty clear I questioned the spool claims for it and stand by that - given that even @reaper wasn't seeing full boost by the rpm claimed.   I'd be interested in the results, I actually have a feeling I may already know someone who has done a 2.8 with a 6870 too.
It's going to give away response to the 6466, and I had mentioned that nitrous would allow you your cake and eat it too if you were only occasionally going to aim for more power.   I'd also personally go an XR9569S hahaha, but 2.8 + Vcam + 6870 sounds like a potent setup to me if you were going to do it.
Edited by Lithium
I’m still going to stick to the 6466 with bigger rear, I’m still curious to see some results though
a 6466 used to its full potential will scare the hell out of pretty much anyone I know which is the main reason I go roll racing
I think a 6870 could be a good match for a 2.8 with vcam and you'd probably be all in under 5. Keen to see someone try it though.
Nothing wrong wit a 6466, its a perfect street turbo imo just doesn't have the legs of the bigger cars.
  • Like 4
Yum, this is my planned next step if I can't get what I want from the baby Garrett :)
Unigroup tuned a 6466 equipped RB25DET non-NEO (home built) with Kelford VCT brap sticks and it comes on about 4k ish and made 465kW at the tyres with 1.8bar of boost. I suspect there's more in it but knowing Yauvz he doesn't like to push motors to their limits (for obvious reasons, warranty!)
Less 68mm more 72 or 76mm
  • Haha 2
  • 4 weeks later...
Did you find big gains going to an RD block? Im thinking about starting to prep one for my car to get that thicker deck. I might need it if we put a little something ontop of the 7685 😂🤦‍♂️
Is yours sleeved or not needed?
It wasn't about gains for me just the added strength. We didn't push it any harder however with double the deck thickness its worth doing.
Downside is the extra weight and it takes a bunch more machining.
Mine isn't sleeved, isn't needed. Just vanilla nitto 3.2 stroker in it.
  • Like 1
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
