On 6/3/2021 at 6:34 AM, reaper said:
It wasn't about gains for me just the added strength. We didn't push it any harder however with double the deck thickness its worth doing.
Downside is the extra weight and it takes a bunch more machining.
Mine isn't sleeved, isn't needed. Just vanilla nitto 3.2 stroker in it.
Do they actually sleeve rd's
I thought once they do they it affects head clamping again?
1 hour ago, Piggaz said:
At what point do you just bite the bullet and go billet? Round and round you go.
at $23k for a block, crank, rods and pistons i dont know why you would go cast anymore. Sure you need to warm them up but its a no brainer if you ask me
  • Like 1
Also don't forget The external oil pump kit you need (wet or dry is up to you)
6 hours ago, r32-25t said:
Was talking to Herman at gtr fest and any block that has been sleeved he automatically condemns it
Is that because of the deck lifting issues or is there another reason?
Because you make the bore behind the sleeve thinner, the cast bore ends up cracking which give no support behind the sleeve and then it ends up cracking
or if you go for the big sleeves with the flange on top you take the complete bore out and a lot of the deck which then take all of the integrity out of the deck and the deck cracks
  • Like 1
Anthony at Dahtone has one  running a Tomei pump that to now hasn't had any issues and its making over 1000hp though hasn't been pushed just yet ;)
I’m going off what both pmc engines and bullet themselves say
I don't believe too many know Anthony has done it yet but he has and its all going well so far. Time will tell though if it stays together or not. Be good if it does
I have seen photos of the engine you’re talking about, but if the guy who builds more of them then anyone else and the manufacturer of the part says not to use it, that a good enough reason for me not to use it.
  • Like 1
If we are talking a track only car sure but for the street I still have my doubts considering how much they grow and shrink.
The weight saving is great but it's honestly never crossed my mind to go billet
I was talking to the owner of the r32 gtr with the plates “billet” he has a 2.8 in a billet block making 1150hp at the wheels and regularly drives it on the street and has done 40 plus passes (best being a 9.0 at 160+mph) and he says it’s never been an issue and he drives it in stop/start traffic and the lot.
What he did say is he changes his oil pretty regularly and makes sure the oil is up to 80° before he drives it and apart from that it’s no different to having a cast block
Peter at PMC has built quite a few billet engines that are in street cars and he reckons they are fine.
How often is “pretty regularly” with oil changes?
He said 300-500kms now that could be over kill but honestly that’s probably about 6 months worth of kms for me which is how often I change it in the gtr anyway
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
