You can all get stuffed. Last night after speaking with Paul I went home and had a hard look atht wheel pricing and figured I wont be hapy until i get them for mine. So once the rebuilt shocks are paid for its time for some 18x10 +35 & 18x9 +25s for my bus. As for you mob with your GTRs...jog on!
:blink:
Oh ... I just went home and ordered a set of them - they are on their way to me as we speak ... you will no longer be a unique snowflake.
(just joking, getting TE's :unsure:)
So the engine bay is DONE! Nismo AFM's in, intake re-assembled, air box sticker charged and intake ducting cable tied down.
Also picked up some rebuilt stocky rear brakes in great nic
And pulled out my mad photoshop skills to confirm that in fact yes, as Anthony put it - black TE's will look tits. Particularly when filled with rotor and AP goodness. Borrowed an 18x10 rotor TE copy toying with the idea of grabbing them as a spare set for slicks but still a bit undecided - I don't think my guards are pumped quite enough.
I am chasing some stock front calipers + rotors + pads + lines if anyone knows of any - preferably in Melbourne. Just as a temporary solution, rotors can be at limit and pads almost gone, just no caliper / line leaks.
Bay looks sooooooooooooooo schmick man. Better than brand new!
Did you run new OEM Nissan front and rear window seal kit..........? Pics with no masking tape.....?
Black TE's will set it off!
FYI - http://www.skylinesaustralia.com/forums/topic/414449-r32-gtr-intercooler-shroud/
Cheers man! Nah just an aftermarket seal front and rear - it's not perfect at the corners but the urethane seals everything up really well.
Tempting group by is tempting - interested in the OEM wing in carbon..... hmm
Picked up these 18x10.5+15 from Import Monster - off getting stripped and painted matte black for the 34 so 32 will have wheels in a week or so. They will definitely get the obligatory test fit on the 32 once they are ready of course for the stance shot before the sensible sized wheels go on.
Wheels back from being painted matte black, the 10.5's actually sit pretty nicely at this ride height. Will get the same treatment done for the 9.5's soon.
Dash chopped to accommodate the cage and gearstick refitted. Have started to fill up some fluids and check over lines etc.
Getting close mate....you must be on edge. Car looks dangerously good, keep photos coming!
Any chance you could post some photos up fo the new front and rear window seals...
Also, did you run new rear quarter windows?
Great build.
That looks awesome. You must be wrapped. Hope the rest goes well!
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
