Thanks boys,,,love her work.
I now sit 1st in class thanks to my old mate Paul changing classes and the other gent(rb25de) not turning up,,,theres no way could I win the shorter hillclimbs against 2 very quick clubmans. I have to be also careful as who knows who will turn up at the following 6 rounds.
The Kuhmo V700's are now officially crap,,,I was hoping they would get better as they wore down but they are getting worse. Everytime I get on the load pedal Cheryl just lights her rears up. Sideways everywhere is fun but bloody slowand the only way I can get the rear end planted is to run with almost a full tank of fuel.
So I've decided to try some Avon slicks,,, after much procrastinating and talking some other competitors I'm buying a newer compound of softs (A94's) at 500 bucks each plus 30 extra a tyre to get this done.
http://www.gordonleven.com/motorsport/about.php
No way can I turn up to the next meeting on brand new slicks so I'm going to try this trick.
Thats a big bite out of my tiny budget so hopefully it works and Cheryl and I can win our class at the end of the year.
Cheers
Neil.
wow that is getting serious, particularly a scrubbing machine! fair enough though when hilllclimb slicks are so expensive and life will be very short.
are you going to drive around the pits with gladwrap on them as well :P
Yep Duncan,,,very bloody expensive but I need traction and I need it in 3 weeks at Kempsey and then Grafton and followed by Tamworth which are all quick climbs. Long ways to go to slip slide around all over the place.
They tell me the life will be longer than I expect because I won't be spinning the tyres all the time,,,we shall see. I had a very lengthy conversation with the boys at Gordon Leven. What will be interesting is they are going to squeaze 250/620x17's onto my 8 inch rims,,,I might need your help massaging the guards out.
Bloody oath I will be wrapping them in plastic,,,actually searching now for some good quality black wrap. Mel doesn't know it yet but she now has a new job before every run.
Cheers
Neil.
Said in a ted bullpitt voice
Not the skyline I just finished glad wrapping the rear hill climb slicks..... Leave Ya money on the fridge wog
Ha Ha your a funny F++uck Pete,,,Bloody Wog.
I could see an A49 (medium soft for rallycross, single seater circuit), and an A92 (very soft for hillclimb, single seater circuit and sidecar wet).
Is there an A94 in there somewhere too, or unlisted?
Dale apparently we shouldn't look at the different compound listings because they change all the time. The A94's are not listed anywhere on the net that I can find,,,do you think I'm just a little nervous?.
I'm tipping a mile-wide grin after the first run.
So this compound is good from cold? Is it the softest in the Avon spectrum for a Skyline size/type/weight/power car?
For more rubber you could always massage the guards with tin snips and angle grinder then fit flares. :action-smiley-069:
My god I hope your right mate,,,shit load of money to spend.
I dragged Duncan out there for his opinion and we got them to fit 1 tyre and match it next to one of my used Federals and it is maybe 1 to 2cm's wider. I was happy,,,he was not,,,I fu+ucking hate it when he's not.
Yes this is a bloody soft avon so it will work from cold,,,so you can bet with all the new traction I will start breaking drive line stuff and kill control arm bushes. Such is life and I'll just have to deal with it.
Whilst I love your flares,,,I'm sort of hoping that I can put that mod off for a little while.
Cheers
Neil.
I've got a guard roller if you need to borrow one. Won't get a lot of "pump" but it helped get the 255/60 17 M/T drag radials under my old boat.
Thanks Mark for your kind offer but I have one as well. Screwed if I was ever going to pay some dickhead to do it for me.
Thats very encouraging to know you got 255/60's under your guards,,,will make me sleep better tonight.
Cheers
Neil.
Well firstly we popped out to Chris at
http://www.cravedcoatings.com/
to pick up my rims and front GTR strut brace bought off Fatz for some powder coating fun.
What a great job this bloke does, Check these pics out.
Yes I'm a little ricey but screw you Pete I like this shit.
That's going to stand out in the crowd, not such a bad thing either.
Thanks mate I actually like them and when I've finished with my Kuhmo's I'm going to get them done in the same colour.
Cheers
Neil.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
