Just found my v35 rims sitting on the doorstep in plain view of the who street, good one stupid courier driver.
just test fitted them and for some reason i dont think i will need spacers on the rear which makes no sense because my 17 x 8 35 offset would not
fit but the 18 x 8 30 offset does ?????????? its only 5mm difference mind you i havent put any rubber on them yet but only been 235 they wont over hang so we will have to
wait and see what happens.
And the the rims arn't in as good condition as i thought they would be, so i might have to give them a cut and polish or re painted.
they look bloody tough and i cant wait to get every thing sorted.
nope
Can you get that stuff in gold....that way it will go with the yellow and you wont see it :happy:
gold would actualy be better because its better at reflecting heat than silver (hence why a mclaren has a gold lined engine bay)
like i said, it doesn't look fancy but you can feel the difference in temperature inside the foam to outside and also quetens down the spool noise a bit too
Got my car back, nice and fixed :P
Also just put a deposit on one of the last 24U blocks made: brand new, and still wrapped: let the engine build begin!!
not going Rb30. . . . disappointed Micah
There is a nice RRR rb26 block on yahoo. . . big $$ thuo
RB26 is what my old man had in the car: RB26 is how I have to keep it - if not for sentimentality, I'd be looking at 3L immediately. With correctly matched turbo and better management, I'm confident it will be what I want it to... Besides, I got the N1 block for a steal!
If you want to keeps yours on the road, I will have a spare rb26 head to sell soon.
N1 block should be sweet. What turbos you going to run?
I just spent 2.5 days polishing mine. Far out, these cars are waaaay too big to polish. Looks great now. Ended up hitting the small scratches with Meguires Scratch X, then did the whole thing with Mother's Clay Bar and then Meguires Gold Class, then Mother's Back to Black on the roof racks and other black bits. Far out what a day!! Kinda ran out of time to do the windows and then take photos before the sun went down :(
My wideband AFR meter arrived today at 3pm, but I had no time to fit it :wub: Back to work tomorrow for 2 weeks, so it'll have to wait a while :wub:
Tried the unique auto sports brake upgrade on the s2 this week . I have to say they do not work on stags . Looking at making my own kit . This will be able to use 324mm disc and the sumitomo 4 pots . Direct bolt on no mods . Have to check on brake lines once on car . Will be out to see a "CAD" man tomorrow . Looking at two different set ups maybe 330mm will fit aswell . Will keep all posted.
booking the car in with chequered tuning (status)to put a nistune in tomorrow should be done by the end of the month as there busy so will have the extra killawasps just in time for deca
very surprised it didn't fit - every skyline brake bit I've put on mine bolted straight on....I've run gtr front and rear brakes on it now?
what was the problem, did the adapter hit on something? Either way Im sure UAS will refund.
+1 on this....I fitted 324mm rotors using R32 GTR callipers with the brackets they supplied me with only a slight mod.
Had a busy week
New front and rear brake disc, pads, braided lines and rebuilt r34 calipers and painted in 2pac
Engine covers painted in 2pac
Greddy copy inlet manifold
650cc injectors and new fuel rail and Sard FPR
Z32 AFM
Fuel pump 13.2V direct feed
New alloy radiator
Next week
GTR BOV
Mod intercooler piping and exhaust
Tune Nistune ecu
Re-assembly front end of car
When time premits parts waiting to go in
Defi 3 DIN gauges
Evo 8 recaro's
GTR front sway bar
Adj caster and camber arms and bushes
Minor stereo upgrade
looking at a decent sized single: T04/GT35 or similar with a modified head, single throttle body and mildish cams: I am gunning for midrange, and don't really car what the peak output ends up being as long as it's responsive...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
