Nice rims too Ben...
I replaced the radiator hoses today, blue silicons to match the cooler piping.
Also ripped the rear disks off to get machined. Found a seized caliper so I ended up having to remove and repair it also. I fitted the QFM pads and bled the system with no other issues. My brakes should be sorted now.
please dont cut em up chuckie....if you don't want them or want something different I'll get a pair of the UAS ones to swap for yours....we can only run the factory ones in production car racing and I've never seen another set
Duncan Don`t PANICK ,I would not do that DUDE REALLY :blink: ,Backing PLATE`S i would like to messs with,only small inlet to ROTOR`S :down: ,so it`s either make only PLAY :bunny: ,look at what i can do with stock backing plate`s,
But I think they make a DIFFERENCE to BRAKING :( Or may be me not driven Bus for while :) ,
But Nice to get her BACK ON ROAD :):) few more small bit`s to sort out ,
JUST happy to have finished main stuff & look at other stuff i need to finish off,
Cheer`s Chuckie.
Finally fitted the last bits of body back to the car... Washer jets, fabric thing under the bonnet and the end caps for the side skirts which are all sikaflexed up and taped on to set... It's amazing how two small things make the car looked "finished"... Oh and installed the hdi d spec boost contoller and boost gauge last night, low boost tuned to 10psi. Will set a high boost after I get a new dump and front pipe. Also looks like I'm picking up my rb30 short motor next week :D
tried to fit the splash guards to no evail... Had both the ones that came off the old car and my s2 ones... Might try some r34 ones and see how I go...
Today my stag got some luuuurve
New oil
Oil Filter
Spark plugs
Injector clean treatment
Tyre rotation
Top up of all fluids
Fixed instrument panel bug I had
Some time this week will change the 3 ancillary belts.
Also discovered my lowerball mount boots are torn and the random leak/weeping from around the back of the transfer case is still around. Will get photos of the leak area... anyone have any experience with these lowerball joints?
This is what 50,000k old Champion gold series plugs look like. Replaced them with NGK coppers will change them more often...
Today when i was at work i put the stag on a pit and removed the front driveshaft, :)
I plugged the hole that the shaft came out of with a small plastic plug.
Then i pulled the 4wd fuse and took it for a spin in the wet :D
Car feels really good in rwd, pretty happy. Glad mine came with an LSD too. I might leave it in rwd for a while.
I noticed a lack of stagea youtube vids, might have to make some vids to put up soon :)
aren't you supposed to let the pressure out of the attesa system as well, i though the clutches for the front shaft were preloaded with pressure?
Nope pulling the front drive shaft is all that needs to be done....
Today i tested out the lsd :)
Then i put my first stag vid up on youtube.
http://www.youtube.com/user/robnuts01
Take your burnouts and piss of mate.... Just what we need posted on SAU. Videos of you doing burnouts on public roads/car parks in Australia in stageas, a car that TENDED to fly under the radar due to MINIMAL cock head ownership
+1
Glad I'm not the only one that thinks your a FOOL!!!
Take you shit else ware!
:D enough said Arse clown!!!!
Edited by Jetwreck
OK well sorry I offended anyone, if i could delete my post i would,
I won't be posting anything like that anymore.
Ask one of the moderators to delete it....I am sure they will anyway.....no offence taken.....just was not the smartest of moves knowing that this forum is not only viewed buy its members but more than likely buy the Police and Media.....you just put a f$#king bit target on your back!!!!
No worries, that's why I blocked my plates. I Really didn't think I would get flamed so hard. Ah well won't make that mistake again.
Peace.
Don't worry about the plates... It's the fact a stagea is very incognito champ... Oh and bright yellow, I'm sure others who have a yellow s2 don't want local cops pulling them over asking about burnout and the such
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
