One common theme I noted from the specs of these 3 GTX turbo's is that they run a slightly larger exducer than previous models, but run comparatively more inducer size....i.e. these 3 GTX turbos all have 58 trim comp wheels - up from 56 trim.
3071 model now also has a .6 comp cover - previously .5 comp cover
Edited by juggernaut1
For some reason when I log into turbobygarrett.com I can't see the GTX series in their catalogue. And the pics hosted on this thread won't open either???
But if Honeywell have stepped up a size on the inducer then it's no wonder they have shifted their maps over to the right and claim they will support higher outputs than the previous GT models.
Was there an update to the turbine specs that they are using, or just the compressor?
This is awesome news, i was just about to buy a new turbo. Thankfully I have been putting it off!
Plus i could not decide whether to get a 3071 or a 3076.... Now I will get get the GTX3071R for sure :D
ATP .
http://www.atpturbo.com/root/releases/release111110.html
Note the compressor housing A/R's , 71R 0.60/76R 0.70/82R Port Shrouded 0.70 A/R .
Without seeing pics my guess is 71R T04E 0.60 A/R , 76R T04S 0.70 A/R Port shrouded , 82R T04S 0.70 A/R Port Shrouded .
Garrett do make a 0.70 A/R T04E housing but its a weirdly shaped casting .
AFAIK the GT40 series comp housings have not been used on Garrett's smaller frame BB turbos .
A .
Edited by discopotato03
For those who arent sure how to plot compressor maps I have done a quick point to point on the GTX3071R.
This is for a 2.5L motor @ 90% VE
Boost shown on the map is 1.5 Bar
For interests sake I also checked the figures at 101% (to push it to its extreme), 3000rpm became 22lb and 8000 became 54lb.
All in all I would say this is an excellent turbo for the 2.5 >_<
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
