The reason being I do not wana leave my car at any shop for more than a day ( I know it can be done in a day by a gun fabricator/mech/welder) and as you said above, the cost implications, but it shouldn't be expensive for some bits of welding and fiddling around... As for selling my jjr dump for $200, I bought it for $179 brand new lol......... And no defects mate, I'm not into screamers, plumb back's for me.
I meant to say its NOT going to cost a bucket load, wasn't concentrating.
You're going to find out the hard way that modifying your car is a process that takes time. You swap out injectors, afm, turbo and get it tuned; you're going to be without your car for more than a day. You can't do without your car then you can't modify it, you need to sort something out anway.
As for defects etc. an aftermarket internally gated turbo is just as illegal as an externally gated one. Just do it properly.
having a stupid looking car and driving it like a stupid then being stupid when you are confronted by popo will probably get you defected just for being stupid,
before an external gate will get you defected for having an external gate...
Lol at ARTZ, that little blue three wheeler on your avatar will surely get you defected mate. For 'driving an extraordinary and potentially dangerous car on public roads'..
Kando's turbos are great. My girlfriends sister has been running a td05-20g on her sr for a year with no dramas and cops a flogging more then often and my mate has had a kando td06 on his rb20 for nearly 6 months now pushing 27 psi on track days and smashes the fkuc out of it and no signs of smoke,shaft play or anything else yet,very happy with a 800$ delivered to door turbo.
awesome, can u tell me what rpm range the TD05 starts spooling on the SR. I just bought a TD05H 18G for $600 shipped. If u pay outside ebay he will knock about $100 off it.
What sort of power are they both making?
27 psi that's a bit drastic did you mean 17 psi? Mine didn't make any more power after 22 pound I'm fairly sure Roy found that to.
1.9ish bar of boost?
Pretty sure these (TD05,06, T67 and their like) wouldn't be able to flow more than 1.7bar (which is what trust quote for similar frame misti's, I would assume that the Kando are much the same). They seem to run out of their efficiency at around 1.5ish IIRC.
Edited by Wheezy
I just read through this whole thread, very interesting read and long lol.
has anybody actually had a td06sl2 20g(external gate) tuned running yet?
also I know a 8cm rear housing is a little small for a rb25 but has anybody out there tried one? Im considering it as I already have a trust td06 kit which needs a rebuild and its a 14cm rear lol, so I want to get a 10cm but Kando/kinugawa dosent have them in 3 bolt flanges. So am considering getting a TD06sl2 20g and running it with a 8cm untill I can find a 10cm turbine housing to swap onto it........ thoughts???? Note im also waiting on a reply to a email if they can get me a 10cm 3 bolt but its the second email and so far no luck
Unless somebody out there has a 10cm and wants a 8cm or a 14cm I could buy the same turbo and swap housings I guess
That won't fix my problem, I have a trust exhaust manifold so I need the mitsu housing ( same as Roy ) unless I change the flange on the manifold, which I don't want to do
Edited by JLTS13
Sounds fine. You will be able to get a 12cm item which should work nice. A little laggier but hey... Cant have everything lol.
If search TD06 triangle housing, you will find the Kando listings for the item. Sometimes they have Kinugawa in the description also.
If you need help determining which housing to get its simple, measure the outer diameter of your turbine wheel. 61mm SL2, 65mm Standard TD06, 67mm TD06H.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
