Well the internal gate 20g sucked balls last night. Well it did perform well except it was running 21psi minimum. This on 98 octane, We got it up to around 280kw.
We tried everything to back the boost down, even had the wastegate flap off and was lazy onto boost but then ran 21psi after 5000.
Ill post sheet up later
Its not blakes old turbo.
Roy at 4750 there is a missfire, i have fitted splitfires which sorted the constant miss, and a few other things but there is a miss at 4750 everytime.
The dyno rpm scale isnt perfect guys. Working off roller speed
I had barely any preload on my last td05h18g and I got full boost 19psi by 4200rpm on a sr but now got another one on the same engine but preloaded it about 3mm 3 complete turns in and now it makes 20psi by 4000rpm
Only difference now is its running eflex e85 where as it was running bp98 before
So not sure if preloading the wastegate tighter made the 200rpm boost response better or the fuel
Ah, k.
Did you try increase the spark dwell?
No i didnt. Car will be back monday night. Worked on ur car, ill try it on the rb25 tomorrow. Only 1 trouble area at 5000.
He is going to weld a new dump to the turbo, the stock setup even with the die grinded outlet sucks balls.
ah me clutch fail!
Did you get a graph anyway?
On the news on poncams for my car, someone has a spare set lying around who I'm going to do some deals with so will have new results soonish :whistling:
Hey Simon how does your old T04Z GTR compare with ur current T67 GTst in terms of rolling runs on the street, take -off and seat of the pants whack?? Much in it?
yeah it should get close, was told it had a new clutch..big words like heavy duty and ceramic were used...
looks like they were just that... words :/
I hate the screamer already, when it first cracked I thought WTF!!!...some more work for you Scotty..lol
Thin red line is my old turbo, I have lost a little down low but it doesnt really feel any slower ..power ramps up so much nicer..
It Did hit 276kw at one point, holds boost nice too
Im just happy I can drive it again and as long as I dont mash the pedal too hard the clutch holds up ok :D
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
