Hey Ben, any word if those holes weaken the bar excessively?
It looks good and should send more air towards the cooler. Very nice.
BTW, where did you pick up the inserts?
yeah, i didn't realise renaults could go so well :D
its funny you should mention that. i was removing some parts from the wreck today. no nissan branding on them. there was renault tho lol
Im sure it must loose some strength... hopefully not too much!
Picked up the inserts from Just Jap $165 Link HERE
Make sure you use R33 inserts not R32 as they have different curves on the insert lip
un opened motor on BP Ultimate.....oh and 15-16psi!
nice result.... query - what size injectors?
my rb25 with 3076IW runs S15 450cc injectors, around 85% duty cycle for 250@wheels. thinking if I add in 550's would get a similar result to yours.
the 370's stockies maxed at 225kw@wheels
The start isn't conclusive as the torque converter isn't locked and the car will kick back if not at a certain speed. You can see the converter locking as the dip at the start.
Rev limit is set at 7200 but they usually shift by 6500 anyway.
Not bad for a GT3071 in the stock housings, Garret .82 wont do that much better, its down around 10kw less than their housings by the looks of it.
May have to upgrade. lol.
might rebuild mine again if im not happy after wednesday :P
I guess its designed to crush during an accident, so it will still serve most of its purpose there. However, the front tow hook also mount onto it- I wouldn't expect it would have the strength to put it out of a bog/ditch anymore. Not much of an issue really, its not like we treat them like a Landcrusier! Except maybe Craig...
Ben - Taste is personal, good on ya for making it your own. If you like it, thats all that counts!:thumbsup:
Thanks man...
I've got 610cc in there....still room to move if I wanted as the highest duty cycle in have seen so far is 67%....that was a run to the end of third gear....I HAD to overtake a couple of semi's! ;)
Thanks man...
And how fast were you going Craig?? lol
its surprisingly hard!
it disfigured in stephens accident but didnt twist or bend the rails. the entire car is dead straight. that bar took all the major damage.
I'd suggest plating the inside edges with some sheet alloy, then welding. That will give back a fair bit of strength.
It will also stop them filling up with small birds etc... :whistling:
Kudos mate, looks great!:thumbsup:
Spent a few hours cleaning the boat yesterday; quick wash, clay, swirl remove, polish, wax. Christ my right shoulder hurts :rofl:
Highlighted how badly my front bar needs to be fixed up too, lots of little chips at the front. The paint is silky smooth to touch now though.
looks great tho duncan. perhaps ask chipsaway (the company) for a touchup quote?
Cheers mate.
Yeah, I would if I didnt need more work done on the front bar - Ive got some cracks in the fiberglass on the passenger side near the headlights :( When I get that fixed up (and the dent above the drivers front wheel arch!) I'll get them to touch up/respray the front bar.
I know some of you are gonna be wanting shift kits installed in the upcoming weeks.
Well Im delaying my tune for about a fortnight - a month as I dont want to have slipping issues.
for the Vic Stagea owners, RVO Automatics in dandenong just quoted me $550.00 for an RE5RO5A(M35 box) Stage two Shift kit..... Installed! I had to ask him three times before he turned around and said "I own a C34 - I know what an M35 is" Lol
if anyone can tell me why I shouldnt take it there, I'de like to know as Im booked in next wednesday :P
Nice work Aaron! :)
No reason why you wouldn't take it there as I have not heard any negative things about RVO.
He knows the transmission.
He knows the car (!!!!)
The price is good.
I guess the only questions is workmanship, but someone has to be the guinea pig ;)
Ask him how much if I just send him the Valve Body....and what's the warranty.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
