What's the benefit of the shift kit? (ie. what does he change, and can you ask for particular performance/snappier gear changes etc.?)
it applys more pressure to the clutch plates quicker so it eliminates slipping depenind on the power you chase.
the gears become more snappier and wont heat up as much causing a 3k + rebuild.
It should also lengthen the life of your gear box
it applys more pressure to the clutch plates quicker so it eliminates slipping depending on the power you chasing.
The all important part of the sentence!
My GB don't like shift ATM!
Today gave the 25G to my son. Yippieeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. He has his Ps. I can now sleep late and drink more.
Nice mate
congratulations in order to the young buck
now, hope he's saving and throws on a turbo, or two, behind your back :nyaanyaa:
I wouldnt say there'll be a warranty unless they're installing it, and like scott says a couple of springs.. but i'll ask n give you a buzz later.
Trans Go shift kit install CLICK HERE
Scott - that's what I was talking about last night.
Thanks guys. I have started already.Got turbo and turbo back and mannifold. Fuel pump and 370 injectors and ecu and AFM. Will go fmic and Greddy FF plenum. Still lots of bits to get but have plenty of time.
Funny thing is he drove the RS4 for the last time when he did the test. A bit ironic.
Hi all i have done the steel fiting out of the back of the thermostat housing mount ! What apain in the rs . But while i was that far in did the timing belt and the bearings that go with it. All the other belts that go with it.
Wooooohoooo. Fixed that stupid farting sound tonight. Visited Kyle who had a spare stock bov and we put it on. No more boost leakage!!!
Talking about gearbox...he actually mentioned his goal was to mate a r34 manual box to his arx...
I would say it is, glad im not the only one in that position. We have some work ahead of us...
BANG! N the turbo has now died.. For the second time lol. Biiiiiiigggggerrr turbo now. So I think I win, I know have more work than u lol
Crap Aaron. What have you done to your car to deserve that? I'm interested so I might be able to keep mine running longer....
I do like your positive attitude though. Spoken like a young person with no kids/mortgage and plenty of time to devote to their car :)
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
