What's the benefit of the shift kit? (ie. what does he change, and can you ask for particular performance/snappier gear changes etc.?)
it applys more pressure to the clutch plates quicker so it eliminates slipping depenind on the power you chase.
the gears become more snappier and wont heat up as much causing a 3k + rebuild.
It should also lengthen the life of your gear box
it applys more pressure to the clutch plates quicker so it eliminates slipping depending on the power you chasing.
The all important part of the sentence!
My GB don't like shift ATM!
Today gave the 25G to my son. Yippieeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. He has his Ps. I can now sleep late and drink more.
Nice mate
congratulations in order to the young buck
now, hope he's saving and throws on a turbo, or two, behind your back :nyaanyaa:
I wouldnt say there'll be a warranty unless they're installing it, and like scott says a couple of springs.. but i'll ask n give you a buzz later.
Trans Go shift kit install CLICK HERE
Scott - that's what I was talking about last night.
Thanks guys. I have started already.Got turbo and turbo back and mannifold. Fuel pump and 370 injectors and ecu and AFM. Will go fmic and Greddy FF plenum. Still lots of bits to get but have plenty of time.
Funny thing is he drove the RS4 for the last time when he did the test. A bit ironic.
Hi all i have done the steel fiting out of the back of the thermostat housing mount ! What apain in the rs . But while i was that far in did the timing belt and the bearings that go with it. All the other belts that go with it.
Wooooohoooo. Fixed that stupid farting sound tonight. Visited Kyle who had a spare stock bov and we put it on. No more boost leakage!!!
Talking about gearbox...he actually mentioned his goal was to mate a r34 manual box to his arx...
I would say it is, glad im not the only one in that position. We have some work ahead of us...
BANG! N the turbo has now died.. For the second time lol. Biiiiiiigggggerrr turbo now. So I think I win, I know have more work than u lol
Crap Aaron. What have you done to your car to deserve that? I'm interested so I might be able to keep mine running longer....
I do like your positive attitude though. Spoken like a young person with no kids/mortgage and plenty of time to devote to their car :)
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
