Me too Andy, roll on weekend for the mock up!
Lets see how good my measuring is... Only other issue I can think of, is that the rotor radius may not fit fully inside the caliper.
Apologies to those who get annoyed with conversations, but did the bleeder valves fit your stock brakes Dale?
So I might be able to make some more money fitting it for them?whistling.gif
You know where it is?
I actually bought them for my new calipers (R32GTR), which are M10, so yes, but the stock rears are an M6 so; no.
Nice; thanks for the offer Craig, hadn't thought of that, was just going to check gasket compatibility as I'm going to need one anyway.
Anyone feel like doing a FAST search on the sump gasket part number? VQ35 and VQ25det?
Apologies for on/off/on/off topic chat... I think?cheers.gif
Edited by Daleo
No apologies needed, gents - the chat is all related to mods you're doing or are about to do.
Today I got this in the mail (because I'm a lazy mofo and don't really like getting my hands dirty):
if you hit it, it would come off.
but the sump plug is at an angle and probably wouldnt come down further than the actual sump itself
this is true.
Are we 14mm?
picked up some new NGK iridium LFR7AIX spark plugs, i had bought 6's instead of 7's and they were limiting my power :( all 6 = $82
also bought 3 quarts of Red Line Gear oil for the Diffs apparently grade 5 shock proof, not that i know what it is. 3 quarts = $75
from perfomanceLUB... guys pretty cheap! after seeing my car i think he wants a stagea lol
this is true.
Are we 14mm?
Can i ask why you used iridiums instead of normal copper?
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
