i didnt start the car but did turn the ignition to put the windows up while i went outside to paint the lights.. so that would be the problem then..
should i do a reset or will it just go away like you said??
thanks for the help..
Cleaned the MAF, Cleaned the Throttle body which was crazy filthy - you could see where the plate was pressing into the build up of gunk.
Re-set the ECU, and Idle (which was 1200rpm after the TB clean!) back down to 650rpm. much smoother and pleasant to drive. Surprised I got it all work 1st go!
Proceed to "test" up the Old Pac Hwy!!!:w00t:
I bought some second hand rims of kidafa. thanks. Well here is what the M35 looks like now.
Well I spent the day fixing gutter rash and then giving the rims a polish. Now the feel like new rims.
did it make a difference aaron?
i like the blacked out headlights. i might practice on the spare i have
like craigs except without the pokemon lazy eyes.
i was thinking of tinitn them.. bit worried though
NICE! Looks a heap better on your white 35 than my silver 34 imo....
May i ask how you de-rashed them?
There is a few tricks to this. You can file out the big marks and hit the smaller marks with some wet and dry moving up from a 240 grit to 2000grit. Once you hit it with some course polish and work to a nice fine polish, you wont notice the gutter rash.
I fitted my towbar to the Stag today. It's been sitting in the Garage waiting for me to do something for a few weeks now. I bought it second hand. I removed the goofy trailer plug and mount, removed some surface rust and gave it a coat of matt black rust stop. It fitted up quite nicely, but it looks like I need to get a new tongue made up as i don't want to cut up the rear lip. Failing that I guess I could space the tongue down by 15mm with a plate.
Thoughts/suggestions??
Had the car since end of Jan and this weekends been the first chance i've got to play on the car, only small stuff thou
1. replaced Cabin Filter
2. installed the Fm band expander (cardealer said they were going to put this in but didn't)
3. Pulled the DVD Rom out and Opened it up to physically clean the laser. Put i back in and now it works
so i can finally have the english conversion done (couldn't read the disc first time)
4, Installed a Reverse camera to the factory tuner, not essential but i figure if you have a Screen on the dash it might as well have a camera
Interior was in many pieces, but all when back together fine with only a couple of spare clips left over.
I did aciddently short the reverse light fuse and couldn't find the fuse to replace it.
wasn't to concerned and was going to sort it out later, until i tried to start the car and found out that it won't start without it
anyway searched the forum and learnt about the 3rd Fuse box hidden behind the battery on the firewall, so alls good again
i always thought the 2 fuse boxes i knew of didn't have enough to cover all the elec systems in the car
and It amazes me how they decided what areas of the Stagea needed to have English text and Japanese text on the other bits
Got the bastard file out and got rid of the rash. Then just sanded the whole rim from 200 grit all the wat to 2000. Then used a powerball and autosol. Alot of hours and sore arms but it was all worth it.
.....the 3rd Fuse box hidden behind the battery on the firewall, so alls good again.....
Easy job replacing the cabin filter? Did you buy a cabin filter from Ebay?
Where's the Second fuse box????? I know of the one behind the battery, I know of the one down near the accelerator pedal. Where's the other? :thumbsup:
i also need to do this so interested in the part number.
my Air con stinks and I have a feeling this may be apart of the reason lol
x-trail, 350z, and a few others fit our car. $25 from nissan. well worth it. i guarantee yours will be black aaron haha mine was filthy!
thanks iain. might do it while scotts attacking the exhaust in a week or two..
Iain,
Let me know if you have any of the centre console of the beige car handy. I still want to remove my 'out of colour' centre section where the stereo goes and replace it with something factory.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
