Installed my whiteline front swaybar today
managed to pick it up for $175 s/h with the hd links on it too
with the old one out I was a little disappointed that they seemed to be the same diameter
but the mounting points for the links are closer to the pivot (less lever arm therefore stiffer bar) and the whiteline bar is solid where i guess the stock one is hollow
It was actually really easy to change, i didn't even jack the car up, just moved it onto the curved part of our driveway so the nose was off the ground a bit
yet to go for a drive but will report back when i do
Dale, are you still selling rear bars? i'd be keen to get one of those too now i have a little bit of spare cash
Got bored this arvo so I threw one of these in my car
But unfortunately I've imposed a ban on driving my car until some other parts arrive, which will hopefully be this week - and THEN I can find out if it makes any difference :ninja:
Don't you have an emanage that needs to go in?
And yes, I'm aware of the irony of that comment. :P
Put your car on a dyno in case the afrs and timing are all wrong. Presumably its not the tunable type?
Its not tunable, but I doubt the afrs will be too far out. No doubt it also still runs a closed loop system, monitoring and self-tuning via the O2 sensor.
Sooooo your the one that got that! I thought it went to LEKS! Bastard! :P
haha so thats who I was bidding against :whistling: Fortunately, another quality part has come to Australia rather than Russia!
About bloody time Dunc!
I've been busy :ninja:
I cant do an Emanage install in 20 minutes :P
and yes, severe irony noted. You got that intake done yet? *ducks*
Funny you should mention that. Goes in tomorrow.
Also noticed now that the informeter is back in injectors are at 95%... Fuel reg is going in.
Spoken to the tuner too. Booked out for a month.
I haven't had my fcon as long as you've had your emanage :whistling:
So you're booked for 1 months time then? :)
If you take out the 9 months I was completely without my car, it's probably equal :P
Not booked in, waiting for confirmation from him.
You had 9 months of car off road to install emanage?
if only! You can still see my car in the crash repairers yard on google maps :D I cant wait till they update that tile one over summer.
R33 gtr strut brace should fit seeing my 260rs has one fitted from factory! Looks exactly the same as my mates on his gtr
Is anyone able to verify this 100%?
Thinking I'll get the HKS brace for my car, but don't want to spend that much only to find it won't fit...
Alternatively, if anyone has a R33 GTR on the Gold Coast, and was willing to spend a few minutes testing...
The strut brace on my 260RS is a spot on match for the one on a mates 33 GTR, I've had his in my engine bay to check this for myself and I'm going to order a 33 brace soon.
Edited by numleg
Put the hdi ebx back on.... Have lost boost on stall launch but when the boost does come on its f$&king scary.
My head down for another tune then out to eastern creek for a run.
let us know when ya going i wanna see your beast run
Edited by numleg, Yesterday, 08:14 PM.
Thanks for that; much appreciated!
The only self tuning the ecu does via the O2 sensor is at idle and cruise. As soon as you put your foot down the O2 sensor has no influence whatever so you really need to know what your afrs are at WOT and a check on the timing would be good as well.
The M35 ecu's definitely seem to self tune to a much higher load than the earlier cars Bob, and anything after 2004 should have a factory wideband sensor allowing the ecu full control of the map + or - 10%.
I agree though, it's a very smart idea to run a separate wideband for safety and nothing beats a tuned standalone if it's available.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
