quick question guys, previously i have gotten mechanics to do the oil changes on my car as its been in there anyway but i'm gonna do this one by myself. What i would like to know is where to get the crush washer for the sump plug from. Will they have a suitable one at supercheap or is it a genuine nissan design that only they sell at rediculous prices??
It should be a 12mm copper washer. Worth less than $1
ok awesome, will have a look at what they've got at supercheap then/might check under dads house first he has jars and tins full of bolts, screws and washers, save myself a dollar haha
I don't normally replace the washer every time, in fact; the current one has been on the sump plug for at least 5 changes.
Another big day in the shed, finally working on my car !
Rack bushes, front upper control arm now has adjustable bushes, as do the castor rods
Just need to get a proper alignment done now
Oh, and also found out that I have eibach springs with my impul super shocks
Neither of which I can find info for
http://performance-suspension.eibach.com/performance_suspension/performance_springs
Just installed slotted discs and some qfc HPX pads.
Also replaced the left front bearing that has been making a bit of noise. And due to. A brittle f2f boot ended up doing one of those. Ended up costing a bit more then I first intended, but I'm happy it's all done
what info? eibach are pretty much the best motorsport springs you can get, the spring rate will be printed on them
I'll go get the code off them but I couldn't see a spring rate anywhere
Might have to remove more dust/dirt lol
Also, to subtract from the win
I also found out that both inner cv boots are split on the front :-(
What's the going rate on someone else to do it? My tools are mostly in Tasmania and I'm up in qld for another 6 weeks
Its a cr*p job well worth paying someone - consider getting the cvs done while its apart.
New windscreen fitted after multiple chips in field of vision.
Annoyingly I mainly dropped it off to get the front windows tinted, after I got in trouble for too many darknesses was added last time.
I only avoided a yellow sticker through smooth talking and bold faced lies with the 16% it had on.
I took it back to the same place that talked me in to going dark to match the rears and told the lady up front i wanted legal tint and a new windscreen...
The guy out the back then took it upon himself to try and match the rear windows again.
Had to sit and wait while they peeled it off again and my arm is still getting sunburnt as they didnt have time to put what i wanted on....
At least the windscreen has been done.
Tried to install Scotty Dump Pipe without a hoist.......FAIL
Do you have ramps? I've changed my dump & turbo (twice) with the car on ramps & axle stands at the back.
However, I do need hardwood planks (old stair treads) to get the car onto the ramps because they 'ramp' up too steep & the front bar will hit.
good luck with that its a fun job!!! try and get the O2 sensor off so you can get to the bolt behind it otherwise get a special ball joint cuppler for the socket not the yoke type cos it'll just bind up..........
Well unfortunately for me I managed to cook my S1 over the weekend. Not liking the look of auto box + awd system but will give me opppurtinity to strip down a motor and learn internals.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
