They installed a Turbosmart Boost Tee that day because the EBC was playing up... I can't really tell you how it is hooked up sorry :/
Other mods are:
Greddy Front Mount Intercooler
3" Full stainless steel Fujitsubo exhaust and stainless steel front pipe with 3" Venom 200cpi hi-flow cat
Nistune ECU
Nismo High-Flow Volume Fuel Pump
HKS Panel Filter
well it is definately an issue with the boost controller or it's plumbing, hopefully they aren't getting you to pay for labour while they learn to do it properly. Boost control is a pretty simple system
Just got some Michelin Pilot Sport 3s put on my car and a full alignment - it already feels like I'm going to love these tyres! More compliant than the Federal 595s, decently quiet (roughly the same as the Feds), and very confidence inspiring so far. Can't wait to put some kays on them and give them some more stick and also try them in the wet.
Lol dude, same here.
One of my all time, least favourite bike tyres...
+1 for that had them years ago on zzr swore i would not have them again then when i got my old gsxr it had them on it but not for long.
Running kuhmo ku36 on the stag at the moment 19s and i really cant complain they stick well wet or dry bit noisy but after gate has been opened a couple of times i cant hear s@#t any way , and they where cheap to boot
Havent done it to it yet, but I bought a new high pressure hose from bunnings which also came with a foam lance... the only rare occasion that I have been excited about cleaning the Stagea..
Edited by S T A R 3 3
So it is most likely a leak somewhere? I would be surprised if they didn't install the Tee properly, but then again stranger things have happened...
^^slight leak from turbo manifold gasket?..thats what mine was, never held boost up top since i imported it
thought it was my faulty ebc,as it had been sitting around for 6 yrs , put on bleeder, same shit
cheers
darren
Edited by jet_r31
Installed a JVC KDR736BT deck in the Stagea. A big thanks to Kenwood and JVC for using the same loom plug barring a single pin which is devoted to the (not in use) remote button/steering wheel control. I had the soldering iron, heat shrink, electrical tape and other bits and pieces out but all I needed was a phillips head screwdriver. :yes:
JB Hifi have 30% off headunits so it was hard to knock back this unit at $122 vs $178 or the alleged rrp $349. The neat thing about this deck is it can connect two phones at once and a more modern IPod/Iphone control than the previous Kenwood deck.
I picked up my new M35 last Friday :)
After a 6-7 year absence from owning an import I am back and happy as Larry.
I'll post some pics after it stops raining and I've had a chance to give it a wash.
The storms here have been arse up. The worst ever.
Had to get the SES to come and chain saw the trees in the driveway so I could go to the bottle shop.
Damn inconsiderate of Mother Nature.
Was so blest the tree that came down just missed the Stags in the drive.
lucky!!! hope it all goes well and stay safe!!!
inconsiderate? but now you have fire wood for winter and someone came and cut it for you
hope everything is ok up there, pretty wet down the bottom of the hill but not much happened here
Damn those Swedes and their keenly priced flatpack temptations.
And their carpark.
I resent that.. ;)
Too bad about the paint though.. What was the cause?
Edited by Miltuun
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
