I notice the handling more with these than with the sway bars.
Yes ive run just sway bars, just braces, both brace and bars and just front sway bar. (Whiteline, superpro & unnamed adjustable front bar). So this isnt just a 'ive thrown the bars on and thats the answer it should be' kinda answer.
Just got the chance to finally take the 35 out following the 2nd 2nd brace install. Very impressed with the way the rear of the car is now tight in and out of cornering. Noticed more traction and control delivery and almost nil body roll. Very happy
  • Like 1
Todays job was replacing the rear door. (As you can see by the photos nissan dont paint the section where the rear door hinges are so rush accumulates). For all those saying you are 'no rust' i doubt it.1e5c2fa9f60418ff66a2acf10bae28cc.jpg7dd3648b027635b73edb3f7dd2d27b8f.jpge77a1a16705966f3e1f3345bfd7379e6.jpgc6c464692f9397b71e0499339b67cca8.jpg8310ae655b28e1b304b101156e3812bd.jpg457cc47d2c220e2c3ff8a98e4cd1a400.jpg
You should cut out the electric lock, button switch , and rear wiper motor and keep for spares.
I have a spare tailgate, I think you have to cut the composite to get to them.
Edited by conan7772
added info
I currently have up for sale the spare rear glass, latch motor, door button, hatch seal rubber & latch motor control box. Far ahead of you.
And no you dont need to cut anything to get them out. Just undo the bolts and get them on the right angles and they will come out. I also plan on deleting the rear wiper just need to find a delete plug im happy with.
Did this a few months ago but only just getting around to posting. Is it just me that gets lazy during winter?
Started with a cracked radiator which I tried and failed to fix with J-B Weld to try and keep me on the road.
Radiator was way past it's used by date so I got a thicker factory replacement.
While the coolant was drained I thought I'd have a crack at my own take on the coolant bypass mod.
A few joins but no leaks so far after a few months. Summer will be the big test.
  • Like 3
Used my sucker to go pick up the latest toy purchase other day.
I love my Stag.  Fast and versatile!
  • Like 4
WTF is that how thin these Radiators are? The factory replacement, is that from Scotty?
Love it, what sort of condition is it in? Good ones are pretty much impossible to find these days
Awesome to see another 1600 saved! Maybe we should start up a Stagea and 1600 owners forum. I think there's a few of us out there.
  • Like 2
Really good condition.  Very little rust.  I thought it must have been resto'ed at some point in it's life but the guy I bought it from has owned it for over 30 years and it hasn't been.
It's got an L20 running straight LPG and a T03.  5 speed stumpy, alloy flywheel and custom built clutch, R180 LSD, disc rear, adjustable rear trailing arms, front volvo 2 spot and 298mm discs, bilsteins all round, front and rear sway bars.  Lots or good stuff.  Needs some panel damaged fixed, the few rust spots taken care of, a ton of rewiring done and a good clean.  Once that's done I'll get the gas bottle recertified or replaced, remove the turbo and get it running on straight gas then get it through rego.  After that the turbo will go back on.  It's currently 180ish rwhp with NA like response which is plenty for me.  I don't want massive HP.  I think you lose the essence of what these things are when you push big HP through them.
  • Like 3
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
