Got the battery replaced in the remote. No more green flashing key symbol on the cluster and the return of the inane joy of unlocking the car from 20 metres away. So joy.
  • Like 1
Just getting the car back on the road after a long period of rebuild and decided to replace the craptastic factory gauges in my 260RS with something a little more accurate and informative...
Left to right: oil pressure & oil temp, boost & fuel pressure, voltage & water temp
  • Like 3
well i got my nm35 back from my mates garage after about 10 weeks. it now has the first uk built highflow turbo fitted & some new bc's coilovers fitted. as it was in the garage my rad got a leak in the fillerneck so had to get one from a nice lad on here. & tomorrow im off wheel shopping.
  • Like 1
Was bored and instead of working the long list of things to do/maintain the stag, i threw it on the Dyno instead to see if it's running fine, not lean as i got Impul Ecu in it now ........
Confirm it's all good, still running Rich as but better than lean i guess.
Dyno in 3rd gear, have 2 pre-run to make sure everything is safe, 3rd run is the power run for fun.
Was going to run in 4th gear but the gear box was heating up so we scrapped that and so now i really have to get off my ass to fit the trans-oil cooler.
Drill out a broken bolt in the intake manifold, replaced with high tensile grade 12.9.
Clean out the throttle body while at it, did play around with the butterfly and lucky enough, the idle is still fine, didn't have to do a re-set.
  • Like 1
So some of you (most of you from Facebook lol) probably know that the stagea was involved in a crash about a week ago.
IMG_1486364535.793506.thumb.jpg.85651443
Damage was as follows:
IMG_1486364589.983151.thumb.jpg.915a97a4
IMG_1486364620.205857.thumb.jpg.c4a49b11
IMG_1486364638.310276.thumb.jpg.d1f9c061
IMG_1486364662.884735.thumb.jpg.df29364b
IMG_1486364780.568453.thumb.jpg.450a80f0
IMG_1486364819.884065.thumb.jpg.9cfe38eb
Honestly not too bad damage for how it was hit, I'd consider myself lucky lol
Today I got some parts (thanks Liam!)
IMG_1486364708.766300.thumb.jpg.dcbae32c
IMG_1486364721.410057.thumb.jpg.da8d1a5e
While the door isn't in pearl white, silvers good enough for now..
I'm going to most likely respray the car in the future anyway.
Here's hoping I can get this subframe in and the old one out ASAP
  • Like 3
previously posted pics of LED High beam install, had my guy put in some LED fogs while I was out of town a few weeks back, no install pics just in action
Fogs with headlights off (just the daytime running light inside each headlight housing)
All of the lights (factory low beams, LED fogs and LED high beams)
  • Like 2
So it's been a pretty successful few weeks or how ever long its been lol. I'm going to try and do this in chronological order but dunno how easy that will be. This will also consist of lots and lots of photos so I apologise lol
First off, I swapped the door over. Only thing is that the inside door handle wasn't working and now after about a week with the door on the outside one isn't working... rip. Lucky I have a donor door :P
The ding still needs to be removed and painted.. got quoted $1200 which just about killed me... so dunno what i'm gonna do there, door still seals so maybe I can live with it till I can get it done and the money bank has some dough. The silver door just gives the car personality right?!?!?
Annnddd the solid Hilux to carry the parts lol
Now. The goodie. Subframe removal and putting the new subframe together but not in,
Considering my uncle and I didn't really have much to go off for directions besides the quick google and got the base stuff figured out we just went straight into it. Didn't run into any issues sides the handbrake cable cover thing getting pulled out and the metal bit getting a bit bent around the edge, but we aren't too sure if we did that or if it had happened from the crash.
IMG_3242.thumb.JPG.0523164503a26052fb056375ecd06a0c.JPGIMG_3243.thumb.JPG.dc18295488523a99764dba25fd3f9091.JPGIMG_3244.thumb.JPG.8d015bcaa8a31c4a39f38f69582cf729.JPGIMG_3245.thumb.JPG.ef25093648244a50080a12ebb1586c02.JPGIMG_3248.thumb.JPG.275cf1d343578a850bdaefbb0b17a3f4.JPGIMG_3253.thumb.JPG.c541806c874f2d12af800234cc572fcf.JPGIMG_3259.thumb.JPG.a0e42e6e75c0630082a863bffe78908d.JPGIMG_3261.thumb.JPG.d95fe773d47e9c12b4d537e816f57e73.JPGIMG_3264.thumb.JPG.49a262e02da8956fd927f90cd78b3c69.JPGIMG_3266.thumb.JPG.61cb1efed4cc3a5d6ce7fad5436e3c62.JPGIMG_3275.thumb.JPG.d89733f74d7e169525707445a048d08b.JPGIMG_3276.thumb.JPG.b0baec7e6265e34c41c470fe5f8af00a.JPGIMG_3289.thumb.JPG.4f9869e33883809fcb6c4a7bc501a7ca.JPGIMG_3299.thumb.JPG.9a6c3d645caa4f7b3cc76b0b11e63b2a.JPG
Check out the shock though >.<
I think all up it took us 6-ish hours, we took our time I guess,
I picked up some V35 coupe rims?? 18x8 30p, my old wheels were 18x8 35p. I honestly don't think they will look that bad.
IMG_3331.thumb.JPG.910ca646bfe3eb10be0edcea654c8131.JPGIMG_3332.thumb.JPG.67d950547e25f1729fafc03af7599d7a.JPG
So that's about it... Subframe should go in the weekend after next.
They will look great on your car, I've got them on mineIMG_0369.JPG.622067ee0ab1416658792ec948a86111.JPG
Yeah they look pretty good on yours, I kinda want to get them powder coated but I'll see how I go lol.
Can't wait to put them on! [emoji2]
  • Like 1
Yep, I'm guessing because your car is white, a slightly darker colour would work well. I've never been a fan of black wheels, though - what's the point in having or buying nice new wheels if you can't see the detail in them.
  • Like 1
17 hours ago, JZMX32 said:
Swapped out my brakes this arvo
Front and rear 370z Akebonos
Endless rotors and pads
Braided lines
Whats the part number and where you got them from? Mainly the SS lines.
That looks like some decent bite there.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
