On 21/01/2018 at 7:11 PM, KiwiRS4T said:
Looking good! So what offsets work on the 8 in rims? Different front and rear?
The width is actually 8.5", and the offset is 45. they sit nicely just a smidge behind the guards. The 235/30 tyres are a bit too slim for my liking, so probably will swap to 235/35 down the track.
Connected my phone to the factory Bluetooth.  Phone controls on the wheel work too. Noticed the voice recognition understands English but you need to know the names of the menus.......  Anyone got more experience?
  • 1 month later...
Installed MCA Street Performance Series coilovers, Driftworks front upper camber arms (approx. -6 deg in front and -5 deg in rear), Garson Deep Racing Ryugi wheels on the front in 18x11 -22 (have to re-lip the rears from 18x12.5 -22 to the same specs as the front before I can run them), painted brake callipers and installed a sub and amp. Nothing too major but its a start on my static VIP-inspired build.
Edited by Caleb_M35
  • Like 2
Brake upgrade on the front completed, they're only little 8pots, 4pots to go on the rears once bracketry is sorted for diameter and offset.
And finally able to get new rims fitted now that brakes are done and allow clearances
  • Like 4
On 4/3/2018 at 5:19 AM, TukeH said:
 Finaly I got fmic installed. I did not notice the difference
Later have to buy aluminium pipes to.
Also I bought bc racing shock cover bags
You need to up the boost to 10 psi
  • Like 1
Will look much like this just tidied up. I have to clean up the clear lenses to go over the front to seal it. The light bar is custom from my company I had. They are about 4 times brighter than the stock high beam. The strip across the top is daytime running light and indicator in one. The halos are park lights so will come on with the auto headlights. The flashing lights in the sides are just for when the cars on show.
It is very hard to recreate the mounting points for the stock HID as I have cut 2 of the 3 off to fit the light bar
Any link to where to get that day time running light? Looks like its made out of silicon?
Aliexpress
http://s.aliexpress.com/vmYN7BFJ?fromSns=Copy
Had to cut holes into the panel to wrought the light. It's too long and to attach you need to buy double sided tape and I drilled holes through to use some wire to make sure it doesn't come off.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
