I forgot to mention that 67% duty cycle was on 98 too by the way....:whistling:
your turbo is prob slightly bigger than mine too manuel so im hoping my injectors will be sweet for 270kw
Do you know what your injector cycle is hitting with 300kw?
  • 5 years later...
8 hours ago, vxsr33 said:
6 year bump.
Is a power fc (r33 gtst) capable of running e85 and flex tune?
I know you need a e85 pump, fuel lines and compatible injectors but what else is needed?
PowerFC can tune for E85 (it's just fuel), but it will not do flex fuel.
But a stock RB20DET with Nistune and the feature pack can control VCT, run full flex, launch control and basic engine protection strategies such as RPM limit vs. coolant temp and max TP Load vs RPM fuel cuts - which a PowerFC cannot do at all.
Sell PowerFC, get Nistune, left over money from PowerFC proceeds to buy a flex sensor.
Nistune doesn't come with APEXi sticker does it? :P
  • Like 1
I didn't know nistune had all those features.
Im tempted to run only e85 as i have a fair amount of e85 stations within close proximity and i have a second car.
Is an fuel flex tune a lot more expensive than a normal tune?
I was thinking of getting an adaptronic if i go flex fuel would this be a good option?
I don't plan any of this soon I'm just trying to gain some knowledge
Adaptronic is a great ECU if you spend heaps of time scaling everything properly, setting up all the tables and working on the timing map to be as near OEM as possible before you start tuning. This is something most tuners don't do because I've seen a good handful of tunes by so called big tuners and they're horrid.
I'm happy to provide anyone with a very good base map to work with, has all the sensors scaled properly, timing map (off boost) as close to oem as possible and all the cranking tables defined nicely so it starts in any weather.
However if you're going to send it to a shop, get a Haltech because their base maps are very good meaning your favourite tuner won't need to do much work to make the car drive well.
There was a big thing in Facebook about it a couple of months ago. Shell rep saying that there was basically zero chance of them ever selling E85 at servos in Australia despite them being the supplier for V8 supercars
Would this work with the Modular ECU?
Hi, I've got an E1280s that Ive written custom code for and would be very interested to see your base map as a starting point for my tuning.
Thanks
Alex
Big thumbs up to Johnny's base map for the adaptronic. Ive been disappointed by tunes from "reputable" places.
Adaptronic's base map can only be described as poo. Retarded poo. At least it shouldn't blow the engine unlike some tunes Ive seen from "tuners".
To Johnny's map, I have added a few more degrees of timing in the cruise area and slightly more on the transition to boost around 93kpa.
However from experience the fuel maps are not comparable, you'll have to do the hard yards with your own afr sensor to set the VE values.
Edited by zoomzoom
Happy to send it to anyone and also my final map on my previous motor that spat out ring lands after a years worth of abuse at 370kW+ on the track (not tune related, motor had over 300k kms, and an average of 1.7bar of boost through it - note completely stock unopened, bar head studs).
I believe you can import the map into the modular ECU, at the very least the the tables you need.
  • Like 1
I'd love to have a copy Johnny if you'd be so kind. I am ordering an Adaptronic Modular soon and just assumed that the Skyline plug n play Modular came with a decent base map, seems not!!
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
