Get finance dude, it'll be like $200-300 interest by the time you pay it off.
8k and that's a huge bargain. Beautiful colour too.
Hell I'll lend you the cash...and only charge you one, one and a half points tops.
How come you went to Mohsens ?
Nah legitimately the tip... lol it was for work purposes
Birds go click on the link Nick posted a couple pages back.. dude's ebay ad looks like a 13 year old girl's myspace page
Negz, done a few front guards and kept the lining. Tony's one, jonoes two.. And a few others from the BMW forums aswell. And I got my linig back in too, just lost the passenger side so I have to source a new/used one
ah not bad, i cut mine up as they scrubbed. Soft suspension for aussie roads dont like any offset lol
I think so, he said the only reason it's all passed is because its extremely neat and very well hidden ie gate and big turbo.
But for guard lining? Man it's such a waste of time, and one lining is $70
If you can wait 10 days for shipping you can get it for $50 from japan or $20 From UAE through amayama, 63843-65F00 is the part #
More so on ours as there's wires that run along the top rail and apparently "if the tyre pops and shreds the steel lining can rip through those wires"
I'm sorry but WTF...
so a bit of plastic that flys off if you go past 200km/h is going to protect anything if a tyre pops.
as tony would say
this rustles my jimmys
I lost one of mine coming out of the sweeper at winton and the other on the main straight at PI..
not like the attache too well in the first place, never realized it was a RWC thing tho..oh well.
I lost mine on my old car also and that passed the RWC without. I've noticed that mechanics are very inconsistent with these things.
Still more carrying on about Blown GS i see :D
Not at all surprising when a LS3 (6.2ltr) with nothing more than cams/tune/exhaust will put down 330rwkw N/A - that shit be crazy :D
Friend of mines blown LS1 makes 370rwkw and runs mid 10s, blower sits on about 7psi and it's a stock LS1 with 80,000kms done now with the blower (160,000 total). Gotta laugh at that really - RB26's would be on borrowed time in such conditions.
But i'd still take a 2.6 R33 GTR any day of the week. :merli:
Good work Aaron!
Yeah haha my right undertray and guard liner ripped off down the Sandown straight two weeks ago.
Never to be seen again...oh well...
Thanks, but can't need to have in done within 7 days so he doesn't have to do a full Roady again
as tony would say
Not even, the plastic is that thin that of it does pop it would probably go through it anyway Lol
Aaron looks like your mate in the M3 seems to be pretty popular, looks like he'll take out the prize
Also will be driving my bro's Evo for the next week. Forgot how naice it is to drive
Which evo is it? Care to take me for a spin so I know what I'm getting into?
Yeh, people love his m3, and I think most of his mates have shared the link
Evo 8 MR
Yeah can take you for a spin if you want.
I'll have the car for the next 3 weeks or so, so can do whenever
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
