Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Lol my first track day at sandown when it was wet found out later my tyres were 26psi
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Good to hear! Now you can start winning races :D
Just got an offer for $1500 for the pink S14. might take it. Anyone else want a track use only S14 for moar than $1500? Needs a wheel bearing and manual conversion
My first question would of been - why is it pink
ex queen st car. nuff said. they had cut the numbers out to do some dodgy shit and they had this perfectly good pink car left behind. basically bought it to make a track car, but then it lived in the back of my garage for like 5 years cos of skyline, golf, 240z and a heap of other cars being more fun to do shit with. Now I need to get my garage space back and I need it gone.
Can't be regged... ever... cos it doesn't have a VIN, and it's pink because of some mohomolebos in Syd.
2 get da chix wet cuz
Same colour. even had similarly mohomo chrome wheels that I told em to keep. Mine's a Series 1 (one in the pic is is a series 2). Wouldn't be surprised if this was the car that they used the VIN numbers for. Goddamn dodgy f**ks.
Haha soon...
I hope there will be no surprises when Trent tunes it. Car is hunting pretty bad now. Might have to check over the injectors, turbo, intercooler install
but richo didn't crash it right?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
