This woman looks like shit these days lol. Don't even wanna google image for a picture.
Oh and...Ralph Macchio aka The Karate Kid, is now as old ad Pat Morita (Mr Miyagi) was in the movie. Do you feel old now?
Pulsars are nice pity SSS isn't turbo. Did thought about Pulsar GTI-R, but you get more value for money from WRX over GTI-R.
GTiRs havent aged well and few havent been mistreated either. Though I do know someone who is selling a kinda unfinished project one cheap
http://forum.pulsar.org.au/showthread.php/98344-GTI-R-for-sale
or you could get the 300kw pulsar for $15k
http://forum.pulsar.org.au/showthread.php/89058-N14-Pulsar-SR20DET-(290KW-for-16k)
hasnt updated the post ina while but is E85 now
Can't see it, need to log in, cbf doing that.
How cheap is the GTI-R?
my friend broke up with his gf after 7 years just last week :/
At work I always ask the bride to be how long she's been with fiancé before getting married...varies anywhere from 3 to 10 years, but most are at least 5+ years. Crazy to think that a 7 year relationship could end and then what, assuming you start over again you gotta wait another few years to know if you wanna marry someone!
I reckon once I hit 25 I'll start to feel old :P
Bro I started feeling old after 21. When I started going to clubs and seeing people who looked like they were still in high school, I became old. But meh, I don't act my age anyway.
That's life...
Can clutch / gearbox brahs suss my thread in drivetrain section plz
What kind of rattle? When does it happen; clutch pedal pushed in or clutch pedal out? Or both?
There's a spring that holds the fork in place to prevent vertical movement, but the top of your pivot ball may also be damaged or broken.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
