Call them up, ask to come around to talk to them about some things... or make some other excuse to go around there...
Parents know that boyfriends don't normally do that sort of thing out of the blue, so they'll know whats up... If you know that they know what's up, it'll be easier...
My sisters husband invited my dad out to play a round of golf and asked him about half way through the back 9... he was trying to think of a way to ask for like 6 holes... Needless to say his game was absolutely horrible up until that point ;)
Yeh I agree with the tradition / respect side of it still intimidating we get along but when the day comes ill be packin bricks for sure
Hypothetically
What would you do if he said no?
Not that his going to, its not like your a bum on centrelink
Yeh people ask that but it seems so unfathomable I haven't given it a thought probably be stunned for a minute and ask if its a joke then move on all the same? dunno I know a dude who got told no twice lol
Dezz, loled @ that pic you got tagged in on facebook, looks like you guys were preppin that kids angus getting tackled.
I wouldn't mind getting back into footy, I've got good ball skills *nohomo* however think now over 18s would demolish me, I'm like 72kg 5"9.. see some of the people playing at the oval behind my house and they're f**king huge
Alex, your mrs is Italian. You've got no choice lol
Personally, I'd speak to the parents, but more so to inform them that I'm taking their daughter off their hands. If they're going to say no, they would have done it when we were dating
Fellow brahs who have dusted off the knee cap im curious to know so share your experience did you ask the in laws first or not? If so How awkward was it? How'd ya go about it?
I didn't as I knew her mum could not keep it a secret..
that said she had been asking when are we getting engaged for nearly 2 years so I knew her feelings on it.
thinking about it it's kinda sexist as well.
unless your going to ask your folks as well if they give their blessing..then she can be the last person in melb to know it happening.
I was about to save his life
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
