Yeah I'm already blacked out... Thinking of doing the shiny brassy coloured wastegate actuator as well... Its the only thing that looks out of place atm. Exhaust Mani heat sheild in a matt black heat proof looks baws compared to the rusted old look :D
haha! yea do it.......... almost contemplated doing the inside of the engine bay black too... but that would have been to much. would look good with a white car tho...
Why do you need to carry jerry cans? Unless going long distance there are plenty of United servos around Melbourne.
I'm thinking more for track days/DECA. there's a station walking distance from my place.
Not sure how fuel efficient this pulsar is, battery always gets isolated so never recorded. isn't too bad when off boost.
will get 98 tune, see how turbo handles the motor and if I want more power/boost will go E85 and GTX2871
I also have a scotty intake with a factory AFM and Airbox on the other end of it. cost was about ~250 (for me). Good idea about sticking the rubber to the outside of it for the super paranoid though..
Scotty actually painted mine black, so he's well aware of Vic paranoia
That's because when Scott has nothing better to do, he opens up every single page of SAu and goes through them. It his way of being completely informed
hahahah!
so he desnt have some sort of webcatcher like stao, who knows when ever someone says the word "hypergear"
hypergear hypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergear
you there stao?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
The noise barely changes as the stock airbox is designed to dampen it. With a pod? Then it would be loud...
PM me for info, I don't want to upset the mods... :P
you there stao?
I heard
If you type his name three times
At midnight
He appears and strangles you with a braided oil line
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
