The shape of the isf does nothing for me..
Depends how high.. I dont expect cars to have done 2000km a year but dont want a 2012 with 100,000 either
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-2092174&Cr=7
  • Like 1
I have the 24 or 27mm fronts sitting in my garage. no car to put them on. you want?
I do... Depending on the exact specs of them... are they the adjustable ones?
Condition? Price?
Naw mang, buy a second hand Falcon GT for 50k - 1 year old, brembos, tune it for a grand got a mid 11 sec car chuck some semi slicks on and have some fun at the track if you want too.
Show me a comparable (new) car to this for 50k only other thing I looked at was the 335i but decided on a new GS instead.Then again I aint on dat dere baller spec cash like dezz. If you looking 100k why not just get a 35 GTR tune it on e85 with some mid pipes and be done with it.
Just research possible gearbox issues and what that might cost.. hell even rebuilding my gearbox costs a shitload!
straya!
Why aren't you at your local Ford dealership flogging falcons?
You could save Ford all by yourself by the way you preach Fords...
The only reason ford fpvs failed is the interior IMO it's marginally better than that of a standard base model taxi nobody gonna part with 60+ large for a Cheapo interior finish.. Holden have always out done them inside and the current gen interiors rival that of a euro
Condition? Price?
non adjustable i believe. they're used - were on the car for about 8 or 9 months. I didn't hit anything in that time so they are pretty good i'd say :P $150 sound good?
Actually now that you mention it, Grand Cherokee SRT8 was on my list of awesome cars I would buy if I had the money. Great looking vehicle and faster than a lot of sports cars. Just sell before the warranty is up. 76k new from a quick google.
Toby I'm counting on you to make all this shit possible.
Would f**kin love a maserati but id say the ones I like would still be well out of my price range.
I'm guessing you'd prefer a gran turismo? Startin from $120k~
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
