out at morwell today and had no idea the smoke was so bad from the coal fire going on. you can see the ash in the air, it's building up on the cars. I don't know how the EPA deems it ok to be outside for extended periods.
epa dont know about it.
too busy sending out letters to car drivers.
  • Like 1
sorry to hear. didnt think JZ would be your thing
jay-z.jpg?w=680
Celsior or cressida with 1UZ is where its at for toyotas. JZ's too pricey.
you know big engine toyotas Alvin, what you think?
as mentioned, they're smooth and all, but they lack everything else, power, torque, and are put in cars too heavy for them.
needs turbro in the boot. coolant/radiator set up in the 1uz snorer is stupid, things are overly complicated.
just go 1J.
They issued advice to residents to consider evacuating today apparently due to the air quality (or lack thereof) as they can't guarantee how much longer it'll be like that.
sooo... 892kms on the hilux and it decides to run out of fuel.
stoopid gauge design... ill take a pic later. The needle and lines are misleading. its a terrible dash in general. instead of lines representing 60km/h, 80, 100 etc, it has a solid line all the way round then gaps missing on the 60, 80, 100 marks. actually makes it difficult to gauge if youre under or over speed limit. and of course their lever design reads 500kms in first half of tank and 400 on the second half. f**king toyotas.
Aw, poor you.
Get a pulsar
How many kw can a R33 GT-R fuel pump support in my gts-t? Ceebs going 040...
I've seen them pump out enough fuel to support 450rwkw in a GTR. I've also seen them run out of puff at 330rwkw. Luck of the draw really but will be more than you need.
How much voltage they're receiving is a huge factor in the flow rate (and I'm sure km's also could be a factor)... Wire it up using a relay to get full voltage instead of 15yo thin wiring designed for a smaller pump and you'll be laughing.
  • Like 1
I spy a Simon
Oh hai... Was on my way to the SAUVIC AGM, which was only 10 minutes from here.... or 1 minute if I had turned left instead of right at this intersection.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
