Sounds like Mohsen spotted a niche opportunity to extend his unique brand of bad luck, unwise spending, bipolar decision making and general disregard for sound advice into offshore motoring. And really, why should that kind of retardedness be limited to land?
  • Like 1
heh. $120 a tank for like 60mins ride time. Were people complaining that track days werent bang for buck?
May I ask what the deal is with obtaining a CAMS licence via SAU? Do I become a paid SAU member - and then apply for one?
yeah, there is a thread in Vic section for new memberships and bank details etc.
Once payment is accepted you will receive a membership card and membership number. Then you can apply for a CAMS licence (since you will need those details)
i die
:cheers:
Yeah also interested in getting a CAMS license. Which one should I apply for? http://www.cams.com.au/get-involved/competitors/licence-types
are you using it to get a discount on insurance for the undrivable car that is sitting in the workshop?
THAT is mohsen level
Oh friend, no, this is recent. I did use it to go to Shannons, but until 6 months ago I had no garage.
Prior to that I was paying for reg and insurance with Just cars!
"pretty sure it'll be going next week" ... for about 150 weeks only!
So hitting up rock pool for lunch. Let's see how good these steaks are.
It is good... but I have had better
make sure you get the Harissa with the steak... shit is biblical
Just had a quick squiz at the current menu... i'd reccomend:
rangers valley dry aged 300 day
grain fed
Rib-Eye on the Bone 440g 69 days $75
and tell the chef to cook it how he wants
grain fed
inb4 Birds is the new chef and cooks it well done
  • Like 1
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
