lol you'd surprised at how often that doesnt happen in science. people have feuds that last lifetimes. and usually take their opinion to the grave (especially in physics)
Take big bang theory for example
+ 1
This guy rarely changes his view
  • Like 1
I hear his technique is pretty good
LOL!
I will let Lynnie know.
seeing as Birds gets me to polish his car...I'm guessing no....lol
Haha! I remember him posting up some finished polished pics, so I thought he knew.
well hes watched me do it a couple of items so im sure he does.......I doubt he could be f**ked doing it himself though...
why whats the problem?
Just had an hour long meeting to discuss what we're going to talk about during a 30 minute meeting later this evening... *sigh*
haha/....gold!!
and lemme guess the half hour meeting tonight will be to discuss what happened at the last meeting!
Ok to use those poor countries as benchmarks now..?
For that measure it's more reasonable. To say 'our debts not that bad' is ridiculous particularly when they leave out that it's one of if not the fastest growing debt of all the OECD countries but of course nobody mentions that
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
