What is the best option for side feed injectors that are e85 friendly? Reluctant to convert to top feed at this stage
My car just turned 18 so can legally drink alcohol now
I thought you were selling your car Ric?
There are a few reasons not to go E85...
The need for Jerrycans is one of the major ones since not a lot of regional centres have any E85 at all, so driving to Winton or DECA will use nearly a tank, then the track day, then the drive home...
I do 300+ peak hour km's each week in my car, I could easily switch to E85 (My pump can handle it, and my injectors are 550's... might need an upsize if I want to keep some decent overhead, I pass a few petrol stations with it each day), but its still the hassle of country trips which suck.
I'll do it in the future, but for now, I'm sticking to BP98
Haha yeah
I haven't got Flex fuel tune at the moment, so any long road trips I need to look at e85 stations.
Wifey prob thinks Im a weirdo carrying a jerry can everytime we go somewhere far
Haha yeah
I'm expecting to love it too much to sell it when I get it back all shiny and new. Driving a rental corolla atm and not having powah is driving me mental haha
Who cares what wifey thinks, she's stuck with you now
There are only two e85 compatible injectors on the market I could recommend, ID1300 and Xspurt 1400. Both are 14mm top feed. Other sizes seem to handle it, like the other Bosch sourced Xspurts, but they weren't designed for long term ethanol use.
I can supply up to 550cc in sidefeed injectors, anything larger is generally a drilled highflow. (with the exception of Nismo 750's I think) You can generally buy a top feed conversion kit and the 14mm injectors cheaper than a set of sidefeeds too.
Top feed is an easy conversion, there are plenty of kits available to swap to top feeds on the RB25, and the RB25 Neo engine comes with them stock so it doesn't look out of place. A few have used the Neo rail on the older engine to keep the stock look.
Shit excuse, Simon. E85 conversion need not be permanent.
I've done the country trip on ethanol before, you just need to fill back up with 98 when the tank gets below 10 litres and switch to your heartily rich 98 tune that will run it fine.
As for DECA, if I wanted to do it I'd just switch back to 98 and drive up there on that, then do the event on that. If I wanted to do it on ethanol, it would take a little planning but I'd drive up on 98 with a couple gerrys of ethanol and swap it in when the 98 was low enough. Then same as above when coming home and stopped at a servo with 98.
Adding to Scotty's post, I've never had an issue with my Nismo 555s.
I remember reading a post that Trent made when he was first getting serious about Flex tuning and he was saying that it was taking 2-3 full tanks before the sensor was actually reading anything close to the pure/drained tank E85 figures.
This is true, but a good tuner won't be knife edging it to a certain percentage and you'll have no issues switching from <10 litres of 98 and vice versa. There's plenty of tolerance in a good tune, enough that I've been able to give my car stick after switching without issue. So my E85 tune isn't radical up top, but I still have an extra 40rwkw in the midrange to muck around with.
Some of the guys in the ethanol thread tried to tell me that my E85 tuned engine was going to detonate from accidentally copping a tank of 70% lol
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
