So, Saturday night I had an altercation.
Drinks flowing, everybody joking around. Ripped a joke with some body, he took it seriously and waited till I turned around before he had the balls to take a swing.
Piece of shit goat lovers.
Now at the ear and eye hospital, awaiting possible surgery. Vision in the left eye permanently impaired.
Also. Wtb. 1000cc injectors
Fark mate, doesn't sound good.
Greg is upgrading to 1400's and has 1000's he wants to get rid of. I can ask him if you like. Or I can get new Xspurt 1000's modified to suit an RB26...
f**king coward.
Go to cops & get him charged, then convicted.
Use conviction to aid in filing civil suit.
Sue him for every penny possible.
Once he has paid whatever he can, take him back to court to obtain judgement against him for the debt + costs and force bankrupt him.
Ruin his life as much as possible - legally
Fkn got dman
What did you say? Let us know how your eye turns out. Did your friend step in and sort him out? If not get him done for assault
Apparently I instigated it, I don't really remember the lead up to it but someone was saying I was calling him a fag lol, apparently. I remember him playing along and saying let's go on the grass, all fun and games and he got serious so I left it and walked off.
One mutual friend said that's sexual harassment...
you could have f**ked his mother in front of him. he still cold cocked you.
hope you well mate. ive been glassed before, its not cool.
im guessing he hit you with something to f**k up your eye?!
This is perfect opportunity to call cousins and get old mate cut.
So if he waited for you to turn around, why is ur eye injured?
even more of a dog act.
you confront the flamin mongrel one and one and beat the f**k out of him. telling him your going to do it before hand.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
