That's what's doing my head in. Suppose I'll have to take a passenger ride in someone's gtr to see if they're all they are cracked up to be
In this day and age it seems a well sorted gtt/gtst and a well sorted gtr are much of a muchness as far as actual speed is concerned, unless I'm wildly incorrect
  • Like 1
went to a steak house and ordered their top steak to be cooked as per chefs recommendation, just like wasteland said.... "I'm sorry but you'll have to pick something because I have to write down the order for the kitchen"
Speed perhaps, how they are to be driven is very much not the same though.
Ask to speak to the chef, and then tell the chef to hit the waiter over the head with a spatula...
Chef's recommendation coincidentally blue everytime for less cooking effort
inb4 Hamish hates me
  • Like 1
I'd assume the difference may be traction
shitcunt waiter :/
Actually...
Contrary to popular belief, bleu (it's French fgt) is annoying as hell for a chef and takes longer to cook than a med rare etc.
You have to get the steak out of the fridge and leave it somewhere that will warm it through all the way to room temp without cooking it at all... Which takes ages... THEN you have to cook it... THEN you still need to rest it.
Bleu takes as long to cook (properly) as a well done and ends up with complaints more often than a well done
Actually...
lol i can imagine.
It's just nice to be able to drive on the street with 330rwkw and not have any fear of a full EPA or Defect. GTR engine bays can remain completely stock looking and still make that power which is great. The others are correct though, depends what you like driving more, I've owned 2 33 GTS-Ts, a 32R and now a 33R and the 33R is just miles ahead of all of them.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
