Just got a quote from Shannons insurance...
1993 Nissan Skyline R32 GTST (all mods declared)
Limited car use (10 days per month - my fifo roster days off)
$10,000 cover with $500 excess & my choice of repairer
$998 per year
Quote from JustCar insurance:
Daily car use
$9600 cover with $450 excess & their choice of repairer
$984 per year
Interesting...
Someone reverses into your door and causes some damage... Do you want the car to be resprayed by Jim Bob's Auto Repair (who put in the cheapest possible quote) or do you want Mick to do the repairs properly?
  • Like 1
Jim Bob's all the way.
$998 per year
Daily car use
$984 per year
Interesting...
How is it expensive if you don't use it much?
Doesn't make any sense to me...
Whats everyone elses agreed value & charge by Shannons?
20 something (can't remember) at $2k p.a.
Premium is mainly cos it's a DD and I live in a shithole. If I move down to Frankston, the premium will reduce to 1600 something.
If someone reverses into your door, you have choice of repairer at the expense of them or their insurance company...
Nothing wrong with Just Cars repairers though, they all have to repair to a standard which you are satisfied with or you can challenge it and take to VCAT - not that I think you would have to - Just Cars have a rep to uphold themselves and Mick isn't the only panel beater in town who knows how to spray a car. I used a Just Cars recommended repairer myself despite them giving me a choice, because out of the quotes I got, they were the only ones who were gonna do a proper job and replace/weld in new metal instead of using bog etc. Very happy customer here, aside from my poor decision to choose a low premium / high excess when I signed up...but have saved a bit of coin over the years by doing that anyway.
Pat, do Just Cars offer any limited use policies?
Any you blokes looked into RACV? Their pricing isn't bad, especially compared to JCI.
Wasn't the case for me this time.
RACV doesn't like Epping very much.
$998 per year
Daily car use
$984 per year
Interesting...
In comparison, my R34 GTT was insured for Just cars for 21K, $1000 excess, their choice of repairer, and I had to provide documentation of every mod (which I didnt mind doing).
Premium: $1725
For shannons, same car, got 27k agreed value, my choice of repairer, $500 excess, and it cost $1100 for the year's coverage, and didn't need to see it, but I had that option to increase my agreed value.
Not even remotely close, lol.
Which is great for obvious reasons.
I for one hope scotty's evo is really boring so he can do something really exciting like swap my entire car over while I'm at work. Thats waaaay more fun than a stroked evo, yep.
I pay $75 per month, limited use and it's agreed val $23000 with $500 excess through Shannon's.
The last 2 times my 33 was repaired by Shannon's it was on limited use and they never asked anyway
I was told with Just Cars that I didn't get to choose the repairer when my door was dented in, I just had to take it into their assessment center and they had 3-4 of their workshops look at it and quote on the repair and it went to the cheapest (approx $1k)
Ended up with a 2nd hand door, resprayed very well in white and all my stuff (speakers, window glass, mirror etc) swapped onto the new door).
They scratched the glass badly, tint was destroyed, door didn't actually close properly because the window glass wasn't adjusted at all. Didn't think to check any of this at the time I went to pick it up because it was quarter past 5 and everyone (them and me) were running late for things... Power mirror doesn't work at all anymore and sometimes the window switch stops working (loose connection somewhere, a bump in the road usually fixes it up).
Called up JCI and they said it wasn't their problem, they didn't want to take a report of the bad workmanship, instead I should re-book it in with the workshop that did the repairs. Called the workshop, they said that I'd need to book it back in via JCI as it was an insurance job and that it would be another couple of days I'd be without the car.
Ended up fixing the majority of it myself so I wasn't carless for any more time, inconvenient as hell :(
2 weeks later I got a renewal notice from JCI which was $400 more than the previous year, with a $2k reduction in agreed value. Told them to go fucck themselves and went straight to Shannons now that I can afford to / they'll take me as I'm old enough and have a good history.
ive done a claim with RACV and considering how much they were charging for the premium, the service and perks werent very good.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
