Yeah, nine-deuce
Dr. Drez, dropin skids once again
It don't stop, Punishing punk motherf**kers real quick like
Thomostown style nigga,
Collegues in the motherf**kin house, yeah
34's in the motherf**kin house, yeah
Yeah, straight up, really doe
Breakin all you frontbars off somethin real proper like
YouknowhatI'msayin?
All these sucka ass collegues can eat a fat dick
Yeah, 33, 33, 33, can eat a big fat dick
32 can eat a big fat dick
31, can eat a fat dick, yeah...
guys decided to flush the engine today and poured some water down the spark plug holes, how long do i need to set the airconditioning for in order to bleed the brakes?
thanks in advance.
xo
Did you do a half flush or a full flush? If you only did a half flush, you should try again with a full flush because it's a piece of shït.
Brakes should be bled for 3-3.5 hours depending on the ambient air temperature. You can measure this via the bung in your cat.
