This actually makes sense to me given the shock I experienced at discovering Leesh had never had a slurpee...I acted quickly to fix this
And all the perthfags taking home Krispy Kremes from the airport
Haha and we might be getting our first 24hr Kmart too!
so we had to do overtime last night and one of my workers magically had a head ache and had to go home at 4 yesterday.
so we pushed on and got the job done, scheduled a 7am start today, dude calls me at 7 and says he has a lawyer appointment at 7:30am.
okay then. finally, bust him chillin and doing nothing.
what the f**k
Call him and ask him what's going on and why he couldn't make it into work... Mention that you need reliable workers to get the job done.
Also, track everything... times/dates/conversations in case he tries for unfair dismissal after you boot his arse because he's crap
