i semi-dated chinese once...
something about the forceful parents, dedicating life to studies, disapproving grandparents who lived at home, who also didnt trust anyone with a beard and who also didnt understand why i wasnt studying because my profession isnt translated well in chinese (pick a language)... made it hard for a relationship.
and she was pretty sheltered.
aka didnt want sex. just lots of public affection. a real winner.
  • Like 1
the other kind i know are at the other end of the spectrum...
working at bars, failing studies, lying to parents about said studies + life in general, hair budget exceeding food budget and constantly posting selfies and/or hand gestures.
10403820_542754362496544_166406853503154
a real winner.
and then there are the ones you buy.
who need constant prada and gucci handbags. brand new cars every 6 months etc etc.
and in reality are sleeping with me more than they are you, because well, your rich, but im better looking.
haha
story may or may not be true.*
*cairns has a high population of token asian brides.
*i used to live in cairns.
Possibly the most accurate generalisation I've ever read
a real winner.
Also quite accurate
Chinese girls have always seemed boring as shit to me, too reserved. Those ones you spoke about in your first racist post, at least. It seems like if you were to pursue one they would eventually open up to you and reveal more boring shit under each layer of personality, until you got to Pandora's box, where to your surprise you would find...a plethora of boring shit.
Me: ever done anything adventurous in your life?
Chinese girl: I once played a D minor piano concerto in D major
  • Like 3
I'm sure there's plenty of different shades of boring shit to amazingly out there.
People just take note of the super blah beige personality and the extreme opposite of that (probably due to rebelling against option 1) of the chick with pink hair going all out stereotype.
There's got to be in betweens, but so normal that they're just you know... normal people...
LOL! @ trying to date and figure out a Chinese girl.
I think people would make the mistake of trying to work out things that aren't there.
The fobs I know are pretty straightforward girls, simple priorities that are well sorted and predictable. Seems to me if you want someone that you don't have to figure out, then head in that direction.
Stark generalisations are fun.
Yeah generalisations are fun, cause most of the time it's stereo typically true.
I took an Asian girl out to dinner, under the condition I bring my parents (because she wanted to meet them) and she can bring her friend.
Most awkward dinner ever.
She has lived in AUS for 10 years but still retains the FOB values.
  • Like 1
haha I would rather have a table for one than bring parents along.
there are plenty of people between the spectrums and even the polars can be really cool people. just two noteworthy people I thought fit the stereotype in a depressing way.
birds, what you speak of about the searching for something if ladies open up (their minds/hearts). it certainly drags me along even though until now I hadn't really thought about the 95% of the times the knowledge gained was nowhere near the worth the effort it took to get it.
in gaming terms, it's like an MMO. much heartache, grinding and adult diapers for a very small return. just settle with what you can get cause it's not worth the effort and is a much better investment?
  • Like 2
PS I'm writing this while sitting in a foyer at southland and my outlook on life is changing as more and more track suit pants walk past.
need to get out of here. (least it's not chadstone)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
