Anyone got clutch hookups? Shopping around for a replacement atm. The rougher the better
I know everyone says go to NPC or Nismo but I put an Exedy heavy duty in my car 5 years ago from here (http://www.icesrepairservices.com.au/products.php) and I've never looked back.
For $400 it has held 325kw at 20+ track and drag days.
I dunno if the price is still the same though.
He's got 99 problems but a clutch ain't one
I was going to like this post until I thought about it, because a clutch is, if anything, his one problem right now.
Current HHDBC has been in for a bit under 4 years, not too pleased it's slipping now. Will probably go NPC. What was the damage for yours Toby and Adam?
Mine was about $500-550 from memory; 10" carbotic - biggest clutch that will fit in our bellhousing. I believe they are derived from 350Z clutches. Rated to 300rwkw+
Can get any contact plate you like but I went with an organic cause they said it would stand up to my drag launches...they've been right so far. Also my thrust bearing is being pressed up against the plate (creates a whirring feel through the pedal) and I haven't been assed to adjust/fix it for 3 years now, but she's still going strong...guess that's testament to the bearing quality!
Mine was a NPC Heavy Duty Cushioned Button clutch
I also got a lightweight billet flywheel whilst I was at it.
Total was about $1.1K i think
I got an exedy heavy duty in mine this year, was $1500 though.
this is where I got my Exedy HD..
the R33gts-t HD one a little cheaper than 1500 tho:
http://www.australianbrakesandclutch.com.au/
from their online store
http://www.ebay.com.au/itm/EXEDY-HEAVY-DUTY-CLUTCH-SUIT-SKYLINE-R33-RB25DET-ENGINE92-98-/321462983808?pt=AU_Car_Parts_Accessories&hash=item4ad8afdc80
and install well priced. that 500 quoted above about right,
(oh and if you call it's cheaper so they don;t pay ebay/paypal fees)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
