ok so officially cracked it with news.com.au, I've known it was bad for years but it was easy, however when the 2 main articles for today are:
article 1
EASY KEYSY: How to buy a home with one simple, dirty word
article 2.
‘We just saved $3000 in one day’
THEY saved thousands in hours, and all they needed was one simple secret. Now these Aussies share their shopping tips to help you keep your cash.
So suggestions for Good AU based news sites?
  • Like 1
Track Skyline, boost power a little, drop insurance down loads
Daily Evo, leave stock'ish
Less stress living next to knox, less "not being able to get to work on monday" if something goes wrong on a track day, 4 doors more mohsens
article 1
article 2.
Yeah saw that today. So lame. One talked about saving and the other talked about haggling when buying anything.
Sounds like those stories they run on A Current Affair about how you could save "Hundreds" on cleaning products by going natural... and the end result is instead of buying "Toxic chemicals which could be hurting your family" you make your own at home our of shit like Bi-Carb Soda and Lemon juice... end up spending 2 hours doing 20 minutes of cleaning each week because of your sub-par cleaning products, all to save $200 over a full year.
  • Like 1
Pretty much the story behind every DIY thing that people learn to only do it once...spend twice the time learning something that could be bought with wages from half the time working one's normal occupation!
The time people waste on shit, could get a second job and earn heaps more lol
Yep, but with car or construction based DIY I still find it worthwhile for the satisfaction of doing it yourself.
I don't get that with making lemonjuice in a spray bottle to spritz on my shower tiles...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
