fark that's bad
whats considerably worse than the holocaust is a flashing airbag light
autoelecs attempt and fail, recommend replace items that aren't broken (replaced anyway)
Nissan workshop manual is inconclusive and provides not-possible diagnostic results
google fails
sau fails
genocide is preferable
Did your airbags pop in your ditch kiss?
Or was the impact angle not right to trigger them?
No, it was at very low speed and hit it at the rear... and this is an entirely different car now..
Door button trick doesn't do anything. (wont go from 'user mode' to 'diagnostic mode')
Nissan say that it wont go from user mode to diagnostic mode if battery voltage is under 9V.
Battery voltage is 12.5v.
There's also a god damned mystery yellow plug behind where the head unit goes. There's nowhere to plug this in. Anyone? lol.
fark that's bad
google fails
sau fails
While I'm not sure about this holocaust humor
I had same problem with air bag light .. Do you have neons in the footwell? Or similar ?
Edited by alr33x
in all seriousness holocaust stuff isn't funny, its only funny because of how absurd and so on it is, and its that absurdity that is the funny part
anyhow,
Airbag wasn't triggering on car prior to it receiving my original engine and transmission and ECU's.
It is now. However, the SRS system is supposedly a self-contained system/unit with its own sensors, wires, and so on. Changing an engine shouldn't trigger it from what I can see going by the workshop manual.
Everything is that distinctive yellow, and there's a plug where the stock audio is, except this one is bright yellow. However it terminates short and there's nothing obvious to plug it into. Unsure if unfortunately coloured or god knows what.
Dunno if its even for the airbag, but its suspicious because nothing else was altered and the system won't even enter diagnostic mode to give me flashing lights to find out whats wrong with it all. Given this mystery plug is behind the head unit figured someone may have seen it before when they do something like... change a head unit which is pretty much done in every single skyline in australia
Well if it helps mine was flashing non stop auto elec tried looked everywhere turned out autobarn slightly snipped wire in passenger footwell that was causing the light on dash to flash so they fixed that and problem forever solved
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
