fark that's bad
whats considerably worse than the holocaust is a flashing airbag light
autoelecs attempt and fail, recommend replace items that aren't broken (replaced anyway)
Nissan workshop manual is inconclusive and provides not-possible diagnostic results
google fails
sau fails
genocide is preferable
Did your airbags pop in your ditch kiss?
Or was the impact angle not right to trigger them?
No, it was at very low speed and hit it at the rear... and this is an entirely different car now..
Door button trick doesn't do anything. (wont go from 'user mode' to 'diagnostic mode')
Nissan say that it wont go from user mode to diagnostic mode if battery voltage is under 9V.
Battery voltage is 12.5v.
There's also a god damned mystery yellow plug behind where the head unit goes. There's nowhere to plug this in. Anyone? lol.
fark that's bad
google fails
sau fails
While I'm not sure about this holocaust humor
I had same problem with air bag light .. Do you have neons in the footwell? Or similar ?
Edited by alr33x
in all seriousness holocaust stuff isn't funny, its only funny because of how absurd and so on it is, and its that absurdity that is the funny part
anyhow,
Airbag wasn't triggering on car prior to it receiving my original engine and transmission and ECU's.
It is now. However, the SRS system is supposedly a self-contained system/unit with its own sensors, wires, and so on. Changing an engine shouldn't trigger it from what I can see going by the workshop manual.
Everything is that distinctive yellow, and there's a plug where the stock audio is, except this one is bright yellow. However it terminates short and there's nothing obvious to plug it into. Unsure if unfortunately coloured or god knows what.
Dunno if its even for the airbag, but its suspicious because nothing else was altered and the system won't even enter diagnostic mode to give me flashing lights to find out whats wrong with it all. Given this mystery plug is behind the head unit figured someone may have seen it before when they do something like... change a head unit which is pretty much done in every single skyline in australia
Well if it helps mine was flashing non stop auto elec tried looked everywhere turned out autobarn slightly snipped wire in passenger footwell that was causing the light on dash to flash so they fixed that and problem forever solved
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
