I don't remember meeting you mohsen, can't have left much of an impression.
And don't be ridiculous, no one would post for likes if you died.
I remember the meeting
Something about Mohsen getting his cousins and friends over the other side of the racetrack to beat up Dezz
Dezz saying he'll drop them after he drops Moh
Awkwardness for a couple of minutes
Then sunburn
rofl. and yeah, jonoe almost dying
pat, do not to 26.
it took me an hour to get the bottom afm pipe onto the afm.
to 25/30
dont be a bitch.
i dont remember meeting you at AS nickos.
but i do remember froffin your car on edgars road when i was a young thug muzzin my way through thommo (kid who peddaled everywhere because too young)
also, anyone missing a silver fiat punto?
why do i have people calling up and describing the item but not giving me the make and model number
"hi im calling about the dishwasher you have listed on your website under dishwashers, incase you forgot they wash dishes, are approx 700x700x1500mm in dimensions and resemble large rectangles, i would like a price on this piece of machinery" - exagheration
WHAT f**kING MAKE AND BRAND?
Spent the weekend on the skyrine...
Oil temp sensor installed with thanks to Scotty and his lathe / tapping skills.
Little coolant line that goes behind the block replaced (had previously split and been "fixed" with a straight barb because it was too hard to access)
Intake Middle Gasket replaced with Plazmaman replacement
Wideband gauge installed, still need to punch a hole in the floor with a rubber bung to run the sensor through to my front pipe
Then E85 Tune and Phillip Island on the 8th.
Everything is coming up milhouse!
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
