Gf just spent $120~ on a kettle recently. Good thing it was her own money.
I don't know why you would need a pricey toaster. Does it tell the time? Does it issue you with commands for what to do next? Voice recognition activated.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
