f**k me leeroy, 400 smackers for 100000 k old shocks?!?!
they hard to get or something?
if someone wants them im sure they'll offer something. they're not exactly priced to move. and postage from japan wouldnt be far off that price alone.
Anyone want to do some casual work for an old sau vic exec?
some of the boys from my footy team from hampton park might want work mate. good lads too. any way to contact old mate?
Grant is the one I really have trouble picking
Has been on more international trips than I have local holidays
Bought GTRs and destroyed them
Spends heaps of money on alcohol
Bought more GTRs and then a WRX
Is now planning more travel
Dat Coles casual rate
Rich parents...
Like this chick I know, works casual at Aldi while she studies...Has had boob and nose jobs, in Australia, no Thailand 1/4 of the price jobs... Tells me she worked hard and saved etc.
Yeah you saved your $300 a week and spent $20k+ on surgery, as well as a Europe trip this year, and bigger tits next year...
Rich parents...
pics of said boobs?
  • Like 3
Makes a significant difference
Fair difference depending how you live out of home
Got mates sharing an 8 bedroom house in wantirna their rent is about $80/week a head lol
Still 4.1k per annum + outgoings & groceries etc.
And Fark share housing
First shared house I was at was great. housemates never there so pretty much living by myself for only 1/3rd of everything. Second time not so much. Dude was super passive aggressive all the time and had his stuff spread out all over the house made us feel like we couldn't have anything out anywhere. Then we found out instead of paying equal shares in bills and rent like we'd agreed to we were actually paying for most of and in case of internet more than shit actually cost.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
