Do you have access to replacement ones or are they all faded and shitty due to age? If you're going to be taking them off for paint, you may as well just put replacement ones on...
You will need to remove them to prep them properly or you'll have cracked and cruddy paint within a few months...
So you're pretty much spraying a lubricant on a dried up surface... it'll make it look better very briefly, then look like arse again.
Go to Autobarn and try out a body plastic restorer spray, might last a bit longer... Long enough for a photoshoot either way.
bloody i.t job in mooroolbark aint nobody got time for dat
would spend the extra salary easily on petrol, tolls and time!
simon need to hook me up brah, i can be your bitch but won't be helping your blue ball situation
Edited by UNR33L
Sounds to me like you don't have enough drive... Not willing to push your boundaries enough
Not sure if pun, not for that job.. for a good step up in work I obviously would travel.
SAU LAN FIFO vs I.T workers
Edited by UNR33L
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
