I tasted the foul mediocrity of skyrocketing property prices in my chicken today. Truly felt like I was forcibly tearing the flesh away from the backbone of Australia's cultural diversity.
  • Like 2
Had fish and chips tonight from Captain's Choice Fish and Chips in Brentford Square, Forest Hill... Aussie / Greek by the looks of the staff... Nailed the fish and chips and chico roll
CHIKO ROLL!
Haven't had them in years!
coffe and cars this morning @ road track rally
pretty good setup and turnout
Heading to CUSTOM cars and coffee tomorrow. Carribean gardens 2mins down the rd... Keep the brake dust to a minimum
  • Like 1
