How frowned upon is taking a few sickies in notice period? lol
Keeping in mind old and new workplace are somewhat affiliated.
if you going to, be sure to back it up with a med cert cause it sure looks planned/dodgy...
Never good to burn bridges when moving jobs.
I'd rather get stabbed in my sleep than stabbed in the real world
Dream people can't really hurt you
That's what people thought till Freddy Krueger killed them in their dreams
Frowned upon, if their dicks just do jack shit at work lol
Is the sick day going to be on Monday? When apparently doctors offices are expecting a 1000% increase in visitors coming in for doctors certificates because the government has robbed them of a public holiday?
Compulsory medical certificates for 'sick leave' is the biggest waste of time. Probably clogs up 50% of the doctors office
Should just take it whenever you want, i mean if you take excess its going to unpaid/annual leave anyway
Yeah I think if we take a Monday or Friday or 2 in a row we need a cert.
I've had to fill out a stat dec TWICE because apparently they didn't believe I was sick. Shows how good this place is.
Lol what a waste of time
Because an employee is suddenly going to fill it out and say hang on i wasn't sick you got me. And if you have to get it certified, the other person is really going to know that you were sick on that day....
Get tune, million of comical errors happen.
Then lucky, Osaka imports open, and have the part I need that I spent many hours yesterday trying to get around.
Ace!
Drive there, obtain parts, two infact.
Correct issue with MAP sensor, so car actually running on flex fuel.
So good!
Test traction control, as it's wet outside. Working so well. So effective.
Listening to new album from favourite band, rocking out hard. Life is good. Great start to the day!
Then suddenly, kids run out infront of car. 1m (or what seemed like it) away.
Panic-brake, pull wheel in direction of "not someone's f**king kids", rear end loses it, end up mounting the kerb and parking on the nature strip in a very uncontrolled fashion.
Get out, yell at kids until they're crying because f**k SAKE.
not even my wheel
ffs
Totally because Greg.
Probably a better driver may have managed to countersteer and avoid the kerb, but man, panic braking means very little went through my head.
Still better than putting someone else' head through my front bar.
+1 funnies because its a borrowed rim, which means mine is fine...
I think it's repairable. Just looks like a lot of gutter rash. I do mean a *lot*. It isn't buckled, so I mean hey that's good.. I guess..
Guess whos' booking an alignment, though!
Any pro tips re: Wheel fixers? I asked Alvin as he got my wheels I sold to him repaired and fixed and repainted but no reply because reasons.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
