As someone more inclined to drink them you really should have more
Really fighting temptation to crack one open
I literally bought a chivas 12 to stop me opening the green... i have already had 2 glasses.
I give it till the weekend
Cctv footage of evo car thieves on youtoob.... No number plates (but guaranteed to be stolen) and also a latest model corrola, just like the photos from a recent supra theft in a multi storey car park.
Hi. :action-smiley-069:
Short time poster, Long time lurker.... and your friendly local club secretary.
Membership prices are increasing by $10 each as of midnight 4th July - so if you want to renew, do it now! Just for the member priority entry to SAU NATS if nothing else (which by the way will be in sunny Victoria this year)
Thread with details in the Vic section. :yes:
you have 6 bottles why would you not open one??
what the hell else are you going to do with them.
I have 7 and I'll eventually drink one - rest will be sold for profits or given out as special presents
Shit is like dragonballs
  • Like 1
I've never seen the point in buying shit with the intention of selling it for a profit, if the amount isn't life changing...
Do it enough times in life and it is, good pocket money at least but then we ain't all on dem overtime rates
What I like is that I could sell 3 bottles and the remaining will be paid for so it's almost free goods, just a small amount of effort. Give it long enough and 1 bottle can pay for the remaining 6
But then you got honest, hardworking blokes, like Ric & I, looking to wet our whistles after a long day of business but can't find a single bottle for sale cause Birds cleaned out the store. :(
The struggle is real.
I probably wont sell any. I just love green label
Fuel pump changed - so damn quiet now. 040 bliss
Surprisingly the part that should have been easy; pulling the plastic retaining collar off, was a prick and required a $40 wrench (no getting that off by hand - still needed a heap of force on my long ratchet). And the part that took me 2 hours last time I changed the pump; trying to hook the fkin pump arm onto the bracket, was done in about 5 minutes.
Fuel hoses in the tank were splitting near the hose clamps, within the nipple and still airtight so should be okay, but might need a longer term solution for that. Alas Pirtek aren't open at 9pm.
Hamish what was that restaurant you used to work at when I picked up a stock r33 steering wheel off you? would you recommend for a dinner date?
Cosi, Couldn't recommend due to new ownership.
The new owner's other restaurant is pretty decent though - La Cita
how much you wanna spend per head inc drinks and how fancy?
Just looking for something around the south yarra area, not sure maybe <40 a head
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
