Saw Aston Martin / Jag looking car accelerate rapidly out of driveway in Wantirna...closer inspection it's a Tesla Model S 85
Didn't get a chance to run him, but managed to leave him behind as he followed me out of a slip lane. Silent as a dead man
Keep an eye out for him Leigh lol
LOL, Tesla is pretty deceiving looking thing, In Slovenia, one went past the bus I was in, the car went pretty fast even though the bus was travellign 120km/h.
Thought it was a Jaguar at the first but part of me say it isn't, until I arrived Ljubljana and I'd saw one parked next to charging point, and gave it a closer look. God, it's good looking thing that, dare I say it's better looking than Jaguar XJ.
$88.40 x 12 = $1060/year
In the past 12 months I haven't paid for a single one of the 3 month long contact lenses I use (perhaps $500?), and about half of my new pair of glasses ($300 off) was covered. And I haven't even touched the physio extras that are thrown into my package.
So for me, a few hundred bucks out of my pocket to cover me if I had needed hospital, ambulance, etc is nothing...
Alex, that 18 month ahead surgery... would it be classified as a pre-existing condition? If so, you're gonna have a bad time.
r32 gtst was below the power:weight ratio.
Had a nice discussion with pettet as he tried to book me for high powered vehicle.
That's some old school defecting right there
He must have been only a cuntstable then
  • Like 1
Silent assassin, I'll show him what a real engine does
I had a good example N/A 33. made 125rwkw ish on that springy motors sau dyno day (roller dyno ZOMG)
GTSTs with the usual intercooler exhaust pod filter boost were making 175 ish?
125rwkw was enough to have fun at decas
(P85D)
515kw..(with very minimal drive train loss)
931 N·m
AWD..
11.6 1/4 when first out,
apparently have been reflashed to make them faster since.
just stick some better tyres on them and you got a 10 sec car..
Oh it was the top model one? dat shiz is 170k Then yeah that would make things a little more difficult, I still did an 11.6 though! :D
Maybe I'll put the extra 110k in my car and see what it does :P
Also unrelated Birds, gonna see if JB will match this price for the 70" Sony
https://www.ozbargain.com.au/node/182443
So you rate em?
Edited by UNR33L
Guest
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
