okay f**king pissed off
doing the big score the obvious way and keep getting f**ked over with the driller mission - totally can't get this thing stealthy, and i just can't f**king get away with it
after 7 attempts tonight, f**k that
What are you having issues with?
Took me a few goes to lose the cops then had to have a few goes at the heli part to get it done as well.
I pimped out an audi q7 lookalike to do the getaway and in hindsight it probably wasnt the best idea
Haha, I used an LWB Sandking. Was perfect for my method of law enforcement evasion.
Wait a second, is he talking about the prep mission where you need to steal the tunnel boring machine? Yeah, that's a pain, after about 12 attempts I gave up on getting away clean.
I shot all the guards, then hid behind the truck. Wanted level disappeared just as a cop walked around the corner. Jumped in the truck, away I went. Easy the 3rd time around lol. Trying to get away from the cops in the truck was useless
When stealing the driller, you can go around the back in the alley. There's another entrance there with a guard, but next to the lot theres a ladder that you can get on the roof. Just pick off the guards one by one. If the popo come, just hide on the roof until they're gone.
Not sure if it gets the 'stealh' challenge though
Does anyone know how to get the Elegy Rh9 (nissan GTR) Online? i have it in the campaign but don't know if you can get it for the online side of things.
need a garage then it appears on the website for free from your phone.
aprently social club members are ment to get a free garage.... no f**king idea how tho.
there should be a garage symbol on the map of the players colour. holds 4 vehicles. when in the garage, you press right on the d-pad and confirm and you should be spawned in the Elegy.
Spent 1-2 hours last week buying the Sonar dock and finding every single toxic waste barrel. $250,000 to buy property, earns $660,000. the job requires you to basically sail the submarine around the entire map. its tedious, but got the job done in one hit.
also needs to be done for 100%
im mid 70's i think....
still alot of the little shit to do.
would be better if you got shit in online for doing stuff in the game. lost all motivation to clock it now.
Yeah, a lot of little jobs to do here and there.
I'm just concentrating on the main missions and doing all the smaller jobs later.
Anyone seen that part at the top of the highest mountain..
Written on the plank of wood is "return back here when you have completed the story" :O
yea i know what happens. but you have to go there at 2am i believe.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
